PLZ Help Me with My A/C!!!
i replaced an a/c hose today that had a hole in it...the one that goes from the compressor that bolts on to the front of the condensor...
#3 on the diagram
so i then filled it up with 3 oz of pag46 oil and 23ish ounces of freeon...
a/c compressor comes on, air comes out, but not cold
even let it run for 25 mins at full blast
so i then drained it completely from the top service hose and filled it up with 2 ounces of pag oil and 12 ounces of freeon=same problem
please tell me whats wrong! thank you
Modified by lmike6453 at 6:17 AM 4/25/2008
#3 on the diagram
Re: PLZ Help Me with My A/C!!! (lmike6453)
did u use gauges to tell you when you have reached a full charge??...now u said u used Freeon?...i hope you are talking about 134a..cause freeon is for older vehicles...everything has switched to 134a now....
ok so i hear that i may have to have all the air suctioned out of the system? all i did was replace a hose...anyone ever hear of this and how to go about it???
Re: (lmike6453)
yeah thats another problem that is affecting it...sorry i neglected to add it last night...yeah you need a vaccum pump to but a heavy vaccum on the line which that will also take all the condensation/water out...cause under extreme vaccum water boils ....then once u have the vaccume on it, try then to replace 134a
Re: (lmike6453)
yeah thats another problem that is affecting it...sorry i neglected to add it last night...yeah you need a vaccum pump to put a heavy vaccum on the system which that will also take all the condensation/water out...cause under extreme vaccum water boils ....then once u have the vaccume on it, then replace 134a
Re: (Tegraracer90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tegraracer90 »</TD></TR><TR><TD CLASS="quote">yeah thats another problem that is affecting it...sorry i neglected to add it last night...yeah you need a vaccum pump to put a heavy vaccum on the system which that will also take all the condensation/water out...cause under extreme vaccum water boils ....then once u have the vaccume on it, then replace 134a </TD></TR></TABLE>
yes i agree with the bold statement
Traped air and water in the system will both reduce the a/c compressors efficiency. Water is non-compressible and air has no cooling affect like R134. Take it to a liscenced shop and have them pull a vacuum and perform a leak test. Best $50 you can spend. Then have them recharge it for you. Low side PSI should be around 30-40 psi depending on ambient temperature.
