Pics, difference between ITR LCA's and GSR - HELP!
Hey Guys,
I have a 95 GSR, looking at some ITR rear suspension..
I used to have an 88 CRX Si, apparently the LCA's are the same as what I am looking for, problem is - My suspension was changed on the CRX and I'm not sure if I had the original LCA's, does any have pics showing the difference?
And are 88 CRX Si LCA's what I am looking for?
Re: Pics, difference between ITR LCA's and GSR - HELP! (CRXTAZC)
Also, One other question..
I'm currently running an ITR rear sway bar, using GSR end links..
Do I need to get ITR sway bar end links as well?
ITR RLCA's are much beefier. Also if you put them on your "non hype r" integra, the brake lines dont match up to the holes on the lca. Zip ties are your best friend.
Re: Pics, difference between ITR LCA's and GSR - HELP! (tweekerz)
Anybody know if the CRX LCA's are less strong then the ITR, I always thought that they were interchangeable... but I may be wrong obviously..
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz »</TD></TR><TR><TD CLASS="quote">ITR RLCA's are much beefier. Also if you put them on your "non hype r" integra, the brake lines dont match up to the holes on the lca. Zip ties are your best friend.</TD></TR></TABLE>
What about the whole part of them being completely different?
Shock goes on the inside, and not Around the LCA.
These being the ITR LCAs...
http://spoon.org/civic/pics/ITR-LCA.jpg
I remember seeing pics showing older EF-era Civic LCA's and ITR LCA's. I believe they are of similar design, but different lengths, which would seriously throw off your camber, and I mean really, really bad.
Re: Pics, difference between ITR LCA's and GSR - HELP! (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">
http://spoon.org/civic/pics/ITR-LCA.jpg</TD></TR></TABLE>
Nice addition. And yeah, I'm running them and the camber is bad.
Thanks for the info guys..
So I need a set of ITR LCA's, that should be interesting...
What about the trailing arms? they will remain the same?
comptechgsr
09-15-2002 12:00 AM
