Performance Aluminum Radiator or OEM replacement? - Honda-Tech
Old 04-05-2013, 08:47 PM   #1
ef8-dc2619's Avatar
Default Performance Aluminum Radiator or OEM replacement?
So my oem DC radiator with 130,XXX miles is now leaking from the tank where it meets the top. Its time to upgrade right, so I need some feedback to see what works for me. Its my DD and moderately beat upon, mostly babied.
I need something thats direct fit and wont interfere with any oem fans or ac stuff.
leaning towards:
skunk2 alpha
mishimoto
Help
ef8-dc2619 is offline   Reply With Quote
Old 04-05-2013, 08:54 PM   #2
racebum's Avatar
Default Re: Performance Aluminum Radiator or OEM replacement?
the best of the breed is the koyo. it uses real brazed tubing and holds up to track abuse
that said i would get another plastic tank from rock auto. the full size integra radiator from the factory is actually quite large for the displacement of the engine.
the stock fans won't fit any of the aluminum radiators except the koyo and that radiator is so thick you can't use stock fans and a header. then again it's so thick you don't even need fans. i kid you not i had one of those on the type r and in 100deg weather. in traffic....no fans, it did not overheat.
you can either get a spectra via rock auto or amazon or the koyo OE plastic radiator is part number W0133-1608401
the big aluminum one is on ebay for $300
something like this is cheap and gets you back on the road
Spectra Premium CU1741 Complete Radiator for Honda Integra : Amazon.com : Automotive Spectra Premium CU1741 Complete Radiator for Honda Integra : Amazon.com : Automotive
racebum is offline   Reply With Quote
Old 04-06-2013, 08:17 AM   #3
drmix's Avatar
Ive only heard good things about the Mishimoto and is what I plan on buying for my car next. Its got a lifetime warranty as well. The only thing that sucks is you will have to replace the fans to work with this radiator.
drmix is offline   Reply With Quote
Old 04-06-2013, 08:35 AM   #4
fcm
Old Fart
fcm's Avatar
Mizu rads from sparkplugs.com...
http://www.sparkplugs.com/Automotive-l134.aspx
http://www.mymizu.com/acuraradiators.html
Works great in my 94 RS, good drop in fit, well made rad, direct fit OEM rad fan, and great service from sparkplugs.com 94
fcm is offline   Reply With Quote
Old 04-08-2013, 07:05 AM   #5
S2BumpsticksGSR's Avatar
If you get alum, buy an anode for drainplug- it will keep corrosion(scaling) from building up inside system
S2BumpsticksGSR is offline   Reply With Quote
Old 04-13-2013, 11:16 AM   #6
ef8-dc2619's Avatar
so I ruled out any alluminum radiator due to header and fan fitment because I dont have the money for slim fans atm. So now I want a koyo radiator either oem replacement or S series the deal now is I cant find one that says showa replacement, all I see is denso only
Old 05-08-2013, 07:11 PM   #7
gomer124's Avatar
Has anybody actually bought the cheap 30.00 radiators off ebay?? I wreck my hatch every 3 months and am going broke lol, so I'm switching to the ebay radiators....any suggestions or warnings?
gomer124 is offline   Reply With Quote
Old 05-09-2013, 02:58 AM   #8
drmix's Avatar
Quote:
More of a reason to go with Mishimoto. The lifetime warranty covers accidents.
http://www.mishimoto.com/warranty-info.html
Old 05-09-2013, 06:42 AM   #9
Technical Hero
HondaPartsHero's Avatar
I've used both eBay cheapos and recently because of time used a cheapo from advance auto for 75 with a coupon. No difference in quality. I've actually been surprised at the quality of eBay rads and have used about 6 with no issues.
HondaPartsHero is offline   Reply With Quote
Old 05-09-2013, 06:59 PM   #10
nikesb4dub's Avatar
I have the koyo aluminum rad.. v-core 36mm
OEM fitment, drop in. Oem fans fit, etc. I also have a after market header which still has a lot of clearance.
id recommend it
nikesb4dub is offline   Reply With Quote
Oem Itr partout bseries swap parts ef9sirhatch For Sale 3 02-10-2013 10:06 PM
Koyo radiator whiteteggy44 Acura Integra 6 10-09-2011 08:33 AM
What radiator should I buy? Tyounin608 Acura Integra 4 11-21-2006 06:41 PM
Single Row VS. Dual Row Radiator Trian Honda Prelude 3 06-20-2006 09:51 AM
Radiator for SH different?? bubs Honda Prelude 4 01-31-2005 04:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
