PCV Valve symptoms - Honda-Tech
PCV Valve symptoms
Old 03-18-2002, 07:35 PM   #1
eh-D's Avatar
Default PCV Valve symptoms
What are the symptoms that occur when the PCV valve is ready for replacement?
On a 3G Integra is the valve accessible from the top or do you have to access it from the bottom?
eh-D is offline   Reply With Quote
Old 03-18-2002, 07:55 PM   #2
eh-D's Avatar
Default Re: PCV Valve symptoms (eh-D)
Also, will a parts store have a PCV valve? Or am I going to need to go to a dealership for one?
Old 03-18-2002, 08:12 PM   #3
fluke702's Avatar
You could just go to your local car parts store to get it. Or you could also go the dealership if you want oem, personally it doesn't matter to me. It's hard to describe where it is exactly. I know it is possible to change it just by reaching in there if you have a long and skinny arm. If I recall correctly you can reach it by standing next to the right fender and just pull it out. It's about a good arm's length down there.
fluke702 is offline   Reply With Quote
Old 03-18-2002, 08:23 PM   #4
Padronis's Avatar
Default Re: PCV Valve symptoms (fluke702)
I've heard it's good to change it every 12,000 miles.
Padronis is offline   Reply With Quote
Old 03-18-2002, 09:52 PM   #5
eh-D's Avatar
Default Re: PCV Valve symptoms (G2LSS)
Any chance that it could make a high pitched whistle/squeal?
I'm replacing it tomorrow morning becuase I'm sure it's overdue and needs to be done anyway.
But my car has been making this sound off and on since the end of last year.
Old 03-19-2002, 06:13 AM   #6
BSQ
BSQ's Avatar
The PCV valve is on the backside of the engine block underneath the intake manifold on a 3G Integra GS-R. It is not that easy to access. Here is a diagram from the Helm's manual which shows its location.
BSQ is offline   Reply With Quote
Old 03-19-2002, 06:28 AM   #7
ebelp's Avatar
Default Re: PCV Valve symptoms (BSQ)
What does the PCV valve do?
ebelp is offline   Reply With Quote
Old 03-19-2002, 06:32 AM   #8
BSQ
BSQ's Avatar
Default Re: PCV Valve symptoms (ebelp)
This diagram should answer your question.
Larger image: http://www.imagestation.com/picture/...d.gif.orig.gif
Old 03-19-2002, 01:46 PM   #9
ebelp's Avatar
I get smarter by the hour....
Old 03-19-2002, 01:52 PM   #10
I didn't ask for a dime.
Johnny Gasparini's Avatar
If you have those Valvoline oil change places in your area, you can get it replaced there.
Johnny Gasparini is offline   Reply With Quote
Old 03-19-2002, 02:42 PM   #11
PatrickGSR94's Avatar
Default Re: PCV Valve symptoms (JSM)
I have not set foot inside a Valvoline Instant Oil change place since they sprayed oil all over my engine in my old car almost 4 years ago.
PatrickGSR94 is offline   Reply With Quote
Old 03-19-2002, 03:19 PM   #12
Default Re: PCV Valve symptoms (PatrickGSR94)
Hey so how often do you have to replace it? I'm at about 32,000 miles and I have not even checked it yet. Could this cause a idle problem? Also I read that all you have to do is clean it not replace. Is this true?
Fooser is offline   Reply With Quote
Old 03-19-2002, 05:25 PM   #13
Regular Series's Avatar
Default Re: PCV Valve symptoms (Fooser)
A PCV valve is not expensive - two, maybe three bucks. If your car has gone 32k on the original, I'd just replace it. I think in an extreme case it might affect idle, not sure of it though. I believe a non-functioning valve will make for more blowby, poor fuel economy, etc.
Regular Series is offline   Reply With Quote
Old 03-19-2002, 05:42 PM   #14
Default Re: PCV Valve symptoms (risingson77)
a PCV valve that has failed or is functioning improperly can cause a poor idle. When i changed mine i ordered it through http://www.ahmotor.com along with my fuel filter. I put around 20-25k a year on my car so every change all the items at the same time, usually when school gets out in may. the PCV was relitivly simple to access on my LS but i have seen it more tricky to get in the GSR models. The idle will appear to be jumpy once warmed up. This doesn;t apply during cold weather warm up periods, only once the engine has warmed up. I replaced the PCV as well as the fuel filter and noticed immediate difference. Cheap part, pick one up at an auto parts store. Good luck.
maxxdout is offline   Reply With Quote
Old 03-19-2002, 07:59 PM   #15
eh-D's Avatar
Default Re: PCV Valve symptoms (maxxdout)
Changed my PCV valve and my fuel filter this morning.
I guess the original owner thought the OEM parts were good forever. Same parts taht were put in on the factory line in Japan!
My fault for not fixing it sooner.
Idle is smoother, mileage appears better.(I drove 270 miles today and I'm still at 1/4 tank)
Not easy the first time, but I'm guessing next time it'll be 5 minutes tops.
Old 03-19-2002, 08:20 PM   #16
Padronis's Avatar
My Helm manual says check every 60,000 by pinching the PCV hose. If you here a clicking sound it's good. Should have checked earlier.
Old 03-19-2002, 08:25 PM   #17
vhd
vhd's Avatar
to check a PCV valve to see if its still good or not, all you have to do is take it out and shake it, it should make a rattling noise, if not, then replace it cause the valve inside is cloged. it should not affect idle at all if its bad
vhd is offline   Reply With Quote
Old 03-19-2002, 08:30 PM   #18
eh-D's Avatar
My car has 47,XXX and my valve was totally clogged.
Old 03-19-2002, 08:48 PM   #19
whats the part # for the PCV valve? i cant find it on ahmotor.com
vtecdc2 is offline   Reply With Quote
Old 03-19-2002, 09:48 PM   #20
eh-D's Avatar
Default Re: PCV Valve symptoms (HoL Lee SHieT)
I got mine at Orileys'(sp?) for like 3 bucks.
Old 03-19-2002, 10:32 PM   #21
New User
Phat Corolla's Avatar
Hmm..i think I'll have to check mine soon. I have 130,000 miles...I bet it needs to be changed.
Phat Corolla is offline   Reply With Quote
Old 03-19-2002, 11:06 PM   #22
Default Re: PCV Valve symptoms (Phat GS-R)
Does a Oil catch can help? I read that it keeps you engine clean thus making the use of the PCV valve pointless.
Sideshow9090 is offline   Reply With Quote
Old 03-20-2002, 12:34 AM   #23
Default Re: PCV Valve symptoms (Sideshow9090)
yeah, looking at the diagram would the catch can be spliced into where the PCV hose is?? And somebody mentioned (BSQ?) that the only downside to the can is to empty it...how often does it fill up?
Grandprix is offline   Reply With Quote
Old 03-20-2002, 04:29 AM   #24
Wow. I think that ranks right up there when another oil change outfit forgot to put back my dipstick in my old car. What a pack of jackasses. But yeah, when I went to replace the PCV valve hose, the guy pointed it out where it was located and I immediately thought I could place it myself. It cost me $8 but next time around I will just replace it myself.
Old 03-20-2002, 05:35 AM   #25
BSQ
BSQ's Avatar
Default Re: PCV Valve symptoms (Grandprix)
Yes, an oil catch can will prevent the oil vapors from being recirculated back into the intake manifold. The oil catch can collects the oil, which will keep the intake manifold clean. But the oil catch can does not eliminate the PCV valve. The oil catch can actually is spliced in between the PCV valve and the intake manifold.
I have an oil catch can and I empty mine everytime that I change the oil (3,000 miles).
Here is a diagram which shows how the oil catch can works.
You can go to my webpage on a hooking up and oil catch can... http://www.geocities.com/bretq/DIY_O...tructions.html .
[Modified by BSQ, 8:40 AM 3/20/2002]
99 prelude smoking- A LOT of oil going in from pcv valve. 99bb6-vtec Honda Prelude 2 06-05-2015 08:43 AM
Pcv valve question b16a obd0 oodie Honda CRX / EF Civic (1988 - 1991) 1 01-19-2007 05:27 PM
catch can 912 Hybrid / Engine Swaps 3 02-11-2006 08:34 PM
Throwing Cel Code 15 and 4 (OBD-1 P28) EJ2-Fluffy Honda CRX / EF Civic (1988 - 1991) 7 08-30-2005 04:45 PM
where's the pcv valve briangela1 Honda Civic / Del Sol (1992 - 2000) 4 06-09-2002 11:29 AM
Tags
accord, bad, civic, clicking, dirty, faulty, honda, leak, noise, pcv, s2000, supra, symptoms, v6, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
