pcv on the black box and on the intake manifold?
Im having a brain fart right now, but i was wondering if the black box on the back of the block has a pcv valve on it. Mine does, and it runs a line to the intake manifold where there is ANOTHER pcv valve on it.
so are there suppose to be two pcv valves? one mounted on the black box and one mounted on the intake manifold?
Re: pcv on the black box and on the intake manifold?
the block box is the crankcase breather box... on the box is the fitting but on the intank manifold is the pcv valve
The L shaped thing is the PCV valve, all other straight connectors are just fittings for the hoses.
On GSR, the PCV valve is on the black breather box, on the LS/GS, the PCV is moved away from the box, but it's still an L shaped valve.
