P30 VAFC II wiring...need help.
Old 02-12-2005, 12:44 PM
HONDA_TYPE_R's Avatar
Default P30 VAFC II wiring...need help.
Ok, I did a search and came up with http://www.jrponline.com and they had a good diagram on there. I also went to http://www.apexi-usa.com and looked at what they had. I have seen variations b/w both sites in the pin outs on the ECU. I also have 2 documents that I used.
1 was for the P61 ECU (92-93 GSR), and the other a P30
P30_OBD1
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A4 ORN/WHT VTS VTEC solenoid
A5 LT BLU INJ3 INJ3
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
A7 GRN/YEL FLR1 fuel pump
A8 (empty)
A9 GRN/WHT IACV IAC valve
A10 (empty)
A11 (empty)
A12 YEL/GRN FANC Fan Output
A13 GRN/ORN MIL MIL (check engine light)
A14 (empty)
A15 BLK/RED ACC (a/c compressor clutch)
A16 WHT/YEL ALT C alternator
A17
A18 (empty)
A19 (a/t trans only)
A20 RED PCS EVAP purge control solenoid
A21 RED/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
A25 YEL/BLK IGP2 to main relay and to gound for o
A26 BRN/BLK LG1 gound
B1 YEL/BLK IGP2 to pin A25
B2 BRN/BLK LG2 ground to shields for CYP & TDC
B3 (a/t trans only)
B4 (a/t trans only)
B5 BLU/RED ACS a/c switch
B6 (empty)
B7 (a/t trans only)
B8 BRN/RED PSPSW PSP switch
B9 BLU/WHT clutch interlock switch
B10 YEL/BLU VSS vehicle speed sensor
B11 ORN CYP P CYP -P
B12 WHT CYP M CYP -M
B13 ORN/BLU TDC P TDC -P
B14 WHT/BLU TDC M TDC -M
B15 BLU/GRN CKP P CKP -P
B16 BLU/YEL CKP M CKP -M
D1 WHT/BLU VBU Back Up Power
D2 GRN/WHT BKSW brake switch
D3 KS Knock Sensor
D4 BRN SCS service check connector
D5 (empty)
D6 ORN/BLU VTM VTEC pressure switch
D7 LT BLU TXD/RXD (data link connector)
D8 (empty)
D9 PNK ALT F alternator
D10 GRN/RED ELD electric load detector
D11 RED/BLU TPS TPS Signal
D12 YEL/GRN
D13 RED/WHT ECT ECT sensor
D14 WHT PHO2S O2 sensor
D15 RED/YEL IAT IAT sensor
D16 WHT/YEL VREF VREF
D17 WHT MAP Map Signal
D18 (a/t trans only)
D19 YEL/GRN VCC1 MAP 5V
D20 YEL/WHT VCC2 TPS 5V
D21 GRN/BLU SG1 MAP GND
D22 GRN/WHT SG2 TPS GND
I drew out the connector on the ECU and labeled all of the appropriate pins that it says to wire up the VAFC to. However, the jrponline diagram showed a loop that needed to be made with the pressure signal input and output and the VTEC solenoid signal input and output. My question is, do I just wire it up to the appropriate pins as indicated on JRP and APEXi's site, or do I find the appropriate pins to wire up the pressure signal and vtec signals? Posting this in hybrid as well...Thanks for any help given.
its WANG yoO
04-19-2004 07:42 PM
djwest24
03-22-2004 08:16 AM
HavokB18
03-19-2004 05:50 PM
92B20GSR
09-21-2003 09:01 PM
Quick Reply: P30 VAFC II wiring...need help.
