Oxegen sensor and comp code question
I just replaced my o2 sensor with a bosch unit from kragan. My codes that flash ar 1 o2 sensor and 43 fuel delivery system. Did kragan give me the wrong o2 sensor or are there 2 of them for my application. 1991 stock integra.
Is the code 43 to replace the fuel filter or the fuel pump?
Im trying to passs smog but it fails now across the boards. Any help is apprieciated
Thanks
Thanks
Re: Oxegen sensor and comp code question (DRAG lll INTEGRA)
So there are two o2 sensors? Where is the other one? I replaced the one in the exhaust manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">id replace both if u can afford it</TD></TR></TABLE>
waht i meant was both fuel filter and pump..
