only one fan on radiator spins........is this normal?
Old 09-22-2002, 10:57 AM
Dan GSR's Avatar
Default only one fan on radiator spins........is this normal?
I noticed that only one of my two fans spin.....I'm guessing that this is not normal
what to do??
Old 09-22-2002, 11:57 AM
Project X's Avatar
Default Re: only one fan on radiator spins........is this normal? (Dan GSR)
The rad has only 1 fan. The other is the condenser fan which is for the A/C. It will only come up when you turn the A/C on.
Old 09-22-2002, 12:04 PM
Dan GSR's Avatar
wouldn't it be better to wire up both to spin....anyone do this?
do you just wire both to turn on when the radiator fan spins?
would it hurt the a/c system in any way?
[Modified by Dan GSR, 4:05 PM 9/22/2002]
Old 09-22-2002, 12:19 PM
Project X's Avatar
You can, but you need to have a relay in between.
If you wire both fan for the rad, then what are you
going to use for the A/C?
Old 09-22-2002, 12:24 PM
SmokeU's Avatar
Default Re: only one fan on radiator spins........is this normal? (Project X)
Are you having problems with your car overheating?
If not, then leave it alone.
If it aint broke, don't fix it.
meanTheDope
21
08-24-2016 09:20 AM
meanshyguy
03-24-2009 11:53 AM
creepy116
18
12-15-2007 11:15 AM
j.dizzle
04-25-2007 01:22 AM
Quick Reply: only one fan on radiator spins........is this normal?
