Oil Pump Install ???
Old 03-22-2010, 12:59 PM
Naz04ryan's Avatar
Icon6 Oil Pump Install ???
Anyone know how much it cost for a shop to install a new oil pump on an integra, I know you gotta take off the timing belt and drop the oil pan. I am not attempting this heart surgery. Please i would love to hear a few estimates of how much im looking to fork out. I already ordered the new Type R oil pump. I just want to know how much a garage is gonna charge me for the install?????
Old 03-22-2010, 01:49 PM
mouab18c1's Avatar
Default Re: Oil Pump Install ???
Whats wrong with your oil pump? Not sure on the price but it wont be cheap.
Old 03-22-2010, 02:43 PM
Naz04ryan's Avatar
It is clogged i believe - read my thread and let me know what you think it is...
https://honda-tech.com/forums/acura-integra-6/blinking-oil-light-2746285/
Old 03-22-2010, 03:23 PM
mouab18c1's Avatar
So im assuming you switched out the sensor before buying a new oil pump correct? Is this a bone stock ls? I dont think the ITR oil pump will work with the stock ls. Someone correct me if im wrong. If I remember right only the waterpump was interchangeable.
Old 03-22-2010, 04:45 PM
Naz04ryan's Avatar
Yes i replaced the oil pressure switch and Yes you can bolt a type r oil pump right up the a B18A, It is needed when you do LS-Vtec, It is bone stock block & Head, Ill already be a step ahead if i decide to go LS-Vtec. It will flow a lot better that the stock oil pump. More oil pressure is better than none. haha
Old 03-22-2010, 04:48 PM
Naz04ryan's Avatar
Originally Posted by integra_101
If you ever need to replace your oil pump on your 96-up B-series engine, you might as well replace it with an USDM Integra Type-R unit. Integra Type-R oil pumps come complete with the front main seal. These oil pumps are perfect for LS/VTEC or B20/VTEC or any rebuild setups. The USDM Integra Type-R Oil Pump will bolt-up to any 96-up B-series motor. You can use these on 90-95 B-series engines as well, but will have to change the lower timing cover to a newer OBD2 (96-up) B-series lower timing cover, due to the provision on the oil pump for the crank angle sensor, found on all 96-up Honda engines
Old 03-22-2010, 11:53 PM
AcuraLsSE's Avatar
The ITR oil pump bolts right up to a 96-01 b18, anything before 96 requires you to buy a 96+ lower timing belt cover.
Old 03-22-2010, 11:59 PM
AcuraLsSE's Avatar
I know a shop charges about 3 hours just to do the timing belt. Since you're going to have to take off the oil pan as well as the timing belt I bet you're looking at 4 hour min. Given shops at least in my area charge in between $85-120 an hour you going to shove out 4 bills or more.
Old 03-23-2010, 05:32 AM
PatrickGSR94's Avatar
I would say $500-$600 and that's probably a deal. But really, it's NOT that hard to do yourself, although you really should spend about $100 on a GOOD torque wrench to avoid warping your oil pan.
Also, everyone pay attention to this: THERE IS NO SUCH THING AS A "TYPE R OIL PUMP" The OBD-II 96-01 Integra oil pumps were identical ACROSS the board for all VTEC and non-VTEC models, including the RS, LS, GS-R and Type R.
Old 03-23-2010, 08:50 AM
seanbev24's Avatar
X2. If I was doing this to a b18a, I would use a 94-95 GSR oil pump, water pump, and timing belt. All these would be perfect for future LS/VTEC as well.
Old 03-23-2010, 09:41 AM
mouab18c1's Avatar
Thats what I thought, thanks for the confirmation.
Old 03-23-2010, 09:45 AM
integra_101's Avatar
There is such thing as a type R oil pump. I worked at acura.
Old 03-23-2010, 09:53 AM
mouab18c1's Avatar
We are just saying they're interchangeable.
Old 03-23-2010, 10:52 AM
seanbev24's Avatar
I just searched oemacuraparts.com for Type R, GSR, and LS. I used 1998 as an example.
All 3 list the oil pump as the exact same part number: 15100-P72-A01
Old 03-23-2010, 11:10 AM
Naz04ryan's Avatar
Icon6 Re: Oil Pump Install ???
Hey guys, I appreciate all the feedback, Not tryin to start an argument over oil pumps. lol, but i got some feedback from my local honda performance shop and the owner told me to drop my oil pan and check for sludge since i let me car sit for a couple months with the VC off the head, Then replace the oil filter again and put fresh oil in. see how she runs and if its still getting clogged then im gonna replace the pump. Hopefully theres a lot of gunk in the pan and it just needs a good cleanse. too bad you can't just do an oil flush, just like a coolent flush. would prolly fix my entire problem... haha
Old 03-23-2010, 01:51 PM
efvader's Avatar
you are wrong. 15100-p72-a01 serves all.
Old 03-23-2010, 04:47 PM
lol nope. There is an OBD-II Integra oil pump, and an OBD-I oil pump for older Integras. That is all.
Old 03-23-2010, 10:45 PM
AcuraLsSE's Avatar
I can't argue the part numbers being the same but I was told that the type r/GSR had a higher volume than the LS. I did read the article on team integra about them being the same and shimming the spring for more pressure but I thought the type r had higher volume.
Old 03-24-2010, 03:36 AM
how could they be different if they all have the same part number? There's nothing else that distinguishes parts other than part number, that I know of.
Old 03-24-2010, 06:59 AM
seanbev24's Avatar
Magic jdm dust?
To the op, just get the 94-95 gsr stuff (obd1 pump is the same but you want the vtec t-belt/water pump), save money on a lower timing cover, and be done with it. Use the money you'd spend on labor for a helms manual and some quality tools.
Old 02-22-2013, 11:28 PM
95dc2r_line's Avatar
It's ok guy it's just a discussion, we should be thankful for having everyone's ideas, plus this forums for the discussion board and pages.
caspers_hatch
11-12-2005 11:37 PM
eag36
03-30-2005 05:40 PM
ssl2k
03-11-2005 08:51 PM
Galland
13
06-20-2004 01:23 PM
SleepyHF
03-15-2004 08:26 PM
Quick Reply: Oil Pump Install ???
