Oil Pan Gasket??!??
Oil Pan Gasket??!??
I have a small oil leak coming from the oil pan gasket.
Has anyone replaced this before, if so is it dificult? and or does anyone have any tips for me.
Re: Oil Pan Gasket??!?? (AK94GSR)
get at tq wrench and i think its 7 or 8 lbs tq and do a criss cross pattern. just dont overtighten you will pinch the gasket and it will leak.
Re: (supmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supmike »</TD></TR><TR><TD CLASS="quote">would you need to take off headers to get to oil pan?</TD></TR></TABLE>
I don't think you have to you can slide it out. But I did, cuz I was doing a turbo install anyways.
make sure that simply tightening the pan bolts will not solve this problem before replacing the gasket. Those bolts tend to loosen over time and a quick once-over with a socket can usually cure the leak...
Re: Oil Pan Gasket??!?? (roadrunner)
to do this i would take my header off first just to be safe
and thanks for the good tip about torqueing the bolts down again, this may help some but not all
ill check mine
ill check mine
