fuel sending unit?
Old 07-17-2007, 03:14 PM
Baron55's Avatar
Default fuel sending unit?
Today My needle was on E since lunch so i finally fill up and it was only 8.8 gal....? Then after the fill up it doesnt want to hit the F..its about 2 dots from F. This has been going on for a while but i see its getting worse, my fuel light never comes on either....could this be the fuel sending unit? If so, where is this thing and how much is it?
Modified by Baron55 at 10:44 AM 7/18/2007
Old 07-17-2007, 03:27 PM
wegotmorrison's Avatar
Default Re: fuel sending unit? (Baron55)
I dont know, but let me know because my car does the same thing
Old 07-17-2007, 03:30 PM
Sean5826's Avatar
Default Re: fuel sending unit? (wegotmorrison)
probly your fuel sending unit, i have a 94 ls 2dr and its located right under the rear seat if you have a 4dr it might be different idk? im having fuel problems myself
Old 07-17-2007, 06:11 PM
Daisy... Daisy...
Dogginator's Avatar
The sending unit should be part 31.
http://www.sonsacuraparts.com/...dIrno=
Perhaps it can be removed and inspected.
Old 07-18-2007, 09:22 AM
Sean5826's Avatar
Default Re: fuel sending unit? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">The sending unit should be part 31.
Perhaps it can be removed and inspected.</TD></TR></TABLE>
jeeze where were you in my thread i needed a diagram of the wiring for my gas tank and i couldnt find in anywhere...this diagram still is quite what i was looking for because iit doesnt show wiring...i need to find out the proper wiring for my fuel pump, sending unit, and the other items that are connected tot he gas tank by wires
Old 07-18-2007, 09:35 AM
* B A N N E D *
St Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">Today My needle was on E since lunch so i finally fill up and it was only 8.8 gal....? Then after the fill up it doesnt want to hit the F..its about 2 dots from F. This has been going on for a while but i see its getting worse, my fuel never comes on either....could this be the fuel sending unit? If so, where is this thing and how much is it?</TD></TR></TABLE>
Mine use to do that too. I would bring it past E and just keep driving with it well below E and I never ran out of gas. I never tried fixing it tho, just lived with it.
Old 07-19-2007, 07:11 PM
Baron55's Avatar
does the fuel tank have to be taken out for this?
Old 07-20-2007, 01:44 PM
Sean5826's Avatar
Default Re: (Baron55)
no
TypeRobert
09-09-2006 02:06 AM
integRated109
09-12-2002 06:04 PM
laughinxxx
11-14-2001 10:25 AM
ShapeShifterz
07-16-2001 05:42 AM
Quick Reply: fuel sending unit?
