Car can't get to operating temp when driving
Old 04-18-2014, 05:13 PM
B_Swapped93's Avatar
Default Car can't get to operating temp when driving
It's +10ish with high wind as far as outside temp goes, however my teg won't get to operating temp. The gauge never moves...the gauge is fine I've let it idle and get to temp but as soon as a drive it goes down. Here's the details:skunk2 full aluminium rad mishimoto thermostat(opens at 68*C vs OEM 78*C) bwr rad hoses and random walmart coolant as always. This is really annoying my s300 is being fixed so i can't see what's going on with my sensors etc. No vtec so I 100% know it's not the gauge ECT is new also I have the front of my bumper cut out if that matters the idea was for better cooling but I think I've overkilled it my OEM t-stat doesn't help with the issue either it's not even a year old.
Old 04-18-2014, 05:57 PM
95accordCE6's Avatar
Default Re: Car can't get to operating temp when driving
Did you properly bleed the cooling system after the radiator/tstat replacement? Improper coolant mix or an air bubble or a leak/loss of pressure can prevent the car from warming up properly. Does the heat work?
Old 04-18-2014, 06:06 PM
kinda will have another go at bleeding it when I'm home. Also forgot to add the car has no heater core/I shortened the hoses (with proper ones).
Old 04-19-2014, 11:38 AM
bump
Old 04-19-2014, 02:20 PM
TheRealTegger's Avatar
10 degrees Celsius is 50 degrees in the measurement a civilized man would use.
You state that you have both a Mishimoto thermostat and an OEM thermostat. It can't be both of course, so which is it?
If the engine is overcooling, then the thermostat is either the wrong rating, or is stuck open.
Old 04-19-2014, 03:28 PM
it does this **** with both of them.
Old 04-19-2014, 03:31 PM
Then both are sticking open. Or you've got some other issue going on.
Old 04-19-2014, 05:26 PM
I highly doubt they are both bad especially the mishimoto one. anyone else ?
Old 04-19-2014, 05:35 PM
RESIDENT
TypeRfit's Avatar
You either have a bubble or sticking thermostat. I had this issue with my CTR awhile back, the only way I could fix the issue is to jack the front of the car up when I was bleeding it. You can always test the thermostats my putting them in water on the stove and boil the water, if it opens it good and it's a bleeding issue.
Old 04-19-2014, 05:47 PM
I'm kind of at a loss here if everything was bled right, unless the mishi tstats temp is too low (allows coolant to exit engine before it's warm) as well as the oe test at being stuck open (that'd be horrible luck). I'm just throwing things out there now...I'm guessing you upgraded the rad and tstat at the same time, maybe it's possible the oe tstat was stuck open the whole time but it wasn't noticeable with the cooling rate of the stock radiator, and with the skunk2 there's better airflow and coolant passages etc so it cools way faster once you start driving. Honestly I'd find a cheap standard tsat and try that, I could be wrong of course but thats my thought
Old 04-20-2014, 02:31 PM
If your engine is overcooling, then fluid is flowing through the rad when it's not supposed to. Flow through the rad is controlled by the thermostat.
Are you certain the engine is in fact overcooling? How is the heater output? Buy an infrared thermometer (cheap). Drive the car for a half-hour minimum, or until the upper rad hose gets hot. Point the IR thermometer at the head right where the outlet is for the rad hose. For a 78C thermostat and 13lb rad cap, you should have a reading of about 205F.
If you're running a 68C thermostat (why??), you may see something lower than 205, but I would think no less than 190F.
Old 04-20-2014, 02:53 PM
I'm going to jack it up and give that a go there's no heater I removed all that and shortened the coolant hoses at the back with vibrant ones(made for coolant). the 68c one is for the car's time attack events at CSCS I have a random part source one in now my s300 should be fixed this week so i'll use that and see what temps I'm at. Also the car is extremely hard to start in the cold it misfires and stalls and sounds like is has VTEC killers in it.
Old 04-27-2014, 05:50 PM
bump...still +10-14c here.
Old 04-27-2014, 06:24 PM
halfakneegrow's Avatar
try bleeding it again but try to get one of these
Old 04-27-2014, 06:32 PM
That's what I used and kept squishing the rad hoses thing is last year with the stock rad I could go with out bleeding it or just doing it for 5 mins. the car starts up fine now a days I fixed that, the gas tank is being replaced so it'll be a bit before I can test it out again.
Old 04-28-2014, 03:02 PM
bump//
Old 04-28-2014, 04:47 PM
Are you certain the engine is in fact overcooling? Buy an infrared thermometer (cheap). Drive the car for a half-hour minimum, or until the upper rad hose gets hot. Point the IR thermometer at the head right where the outlet is for the rad hose. For a 78C thermostat and 13lb rad cap, you should have a reading of about 205F.
If you're running a 68C thermostat, you may see something lower than 205 but, I would think, no less than 190F.
Old 06-06-2014, 03:37 PM
**** still won't stay hot...if I let it sit for 10 mins or so it will but as soon as a start driving it starts to cool down and no VTEC. Running a part store t-start currently drained a bit of coolant out of my junk2 rad(full aluminium x2 core) any suggestions? I had this issues back with the stock rad also sometimes it will show "cold" on the gauge, but VTEC will still work,
Old 06-07-2014, 03:53 PM
ok the temp gauge will read cold but if you've driven it a bit VTEC will work it seems.
Tmich91
12-13-2018 03:27 PM
djfob
02-16-2018 05:27 PM
TOO MUCH TORQUE
07-28-2010 09:21 PM
miszjackie
Honda Civic (2001 - 2005)
12
03-25-2010 05:46 AM
Ti3d in
08-04-2004 06:38 PM
Quick Reply: Car can't get to operating temp when driving
