oil leak from distributor?
Re: oil leak from distributor? (quikrpm'z)
It could be your cam plug or cam seal, Mine is also leaking at the moment i just have to get the money together to fix it. I hope that helps lates Greg
Re: oil leak from distributor? (97gSrkId88)
I just changed mine. There is an o ring inside the distributor $2 from dealer. Its 2 bolts to remove the distributor. takes 5 minutes. change it!
Re: oil leak from distributor? (S03Burner)
hatchbro
10-13-2004 09:00 PM
