Oil consumption, 2001 GSR.... Went to the dealership today
Old 12-19-2002, 11:14 PM
New User
5-SpeedFreak's Avatar
Default Oil consumption, 2001 GSR.... Went to the dealership today
For the last few months, my engine has been consuming oil. No leaks, but burning oil out the tailpipe at higher RPM's.
I go through 2-3 quarts between oil changes (not pushing the car hard, mostly highway miles) Every week or so I'm topping off the oil. It's getting hard on the wallet. Mobil 1 5w/30 isn't cheap.
I went to the dealership to have them take a look at the car. They changed the oil and replaced the filter. They want me to return to the dealership every 500 miles for the next 4000 miles. They want to keep a log of the oil problem. They need to do this in order to decide what to do next.
What do you think they'd do? One friend thinks they'll give me a new longblock engine. Another says they'll rebuild this one.
TIA.
[Modified by 5-SpeedFreak, 12:53 AM 12/20/2002]
Old 12-19-2002, 11:18 PM
Understeer's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (5-SpeedFreak)
The cheaper solution would be ideal for them...
But I personally would ask them for a new longblock if the problem is not cured after you take it in for short term checkups.
Old 12-19-2002, 11:47 PM
GSNARR's Avatar
hey i also have a 2001 gsr with the exact samee problem and i hate it. I am running AEM cold air Skunk2 manifold, FPR, Cam Gears, DC 4-1 SS Headers, Apexi N1 Exhaust and it has all been tuned by Aieres at Dynamic Autosports. My car runs Strong and hard but burns sooo much oil so if they figure out the problem i would really like to know. It must be something with the 2001's. Good Luck
Old 12-20-2002, 12:21 AM
.Chris.'s Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (GSNARR)
All of them burn oil, just a matter of how much. Might be poor valve guides.
Old 12-20-2002, 02:39 AM
Integraholic's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (Black204GSR)
I know VTEC crossover burns a bit of oil, but I'm not sure if it continues burning oil while in VTEC. I know I like to cross over a whole lot
Old 12-20-2002, 03:01 AM
vntperformance's Avatar
heck...i got a 94 Gs-R 4dr w/about 106k Milage....i run the puppy to 8.2k Everyday....hit VTEC Everyday...and my car doesn't even consume, barely any oil...let alone not smoke..
sounds like either your valve guides....or piston rings...
vnt
Old 12-20-2002, 04:16 AM
ragejed's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (vntperformance)
hahah, drain oil before you go...not too much, and get that long block, bhahaha to stealerships, sorry, they mine was nice to me..untill i put in a "aftermarket clutch" with my new tranny....not the harder clutch impact makes my winndows slip off the tracks, lol
Old 12-20-2002, 05:35 AM
PatrickGSR94's Avatar
vnt
same here, 127K on my 94, zero oil consumption.
Old 12-20-2002, 06:12 AM
greasy007's Avatar
Location: bustanut inside y0 eye, to show yu where i come fr
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (PatrickGSR94)
the topic is for 2001 GSRs,
i have had no oil burning probs,
i run 10w 30 in summers and 5w 30 in winters.
hope the dealer owns up
Old 12-20-2002, 06:19 AM
INTEGRAMIKE's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (greasy007)
I had this same problem with my 01 gsr. about 2qt every 3,000. now w/80,000 miles its blown. I spun a rod bearing most likely due to lack of oil.
Old 12-20-2002, 06:56 AM
my96GSR's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (INTEGRAMIKE)
My 96 gsr was using oil, I even posted a thread about it ( https://honda-tech.com/zerothread?id=340965 ). I changed the pcv valve and switched to 10w30 castrol drive hard, and i have gone 500 miles so far and have used almost no oil. I do drive it hard and love vtec so I know that is where the oil is going. In fact I just changed the plugs and they all looked perfect, go fig. I hope that you get your car fixed.
On a side note, I worked for volkswagen once. Their 2.0 or 2.slows as we called them would burn a QUART every 1000 miles like clock work. The only way that VW would allow the dealer to fix it was if the car started to destroy plugs and just make a freaking mess. Let me tell you when you tell a customer that the oil that it is burning is not a problem but a FEATURE it makes them just want to hit you. Again Good Luck.
[Modified by my96GSR, 3:57 PM 12/20/2002]
Old 12-20-2002, 07:49 AM
PainfulTeg's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (my96GSR)
well, if you think about it, the only things it could be that are worn are either the piston rings which when they go bad, will pass combustion into the oil which leads to the breakdown and thinning which leads to the oil being passed thru the exhuast...OR it could be the valve guides, when worn they will also help pass oil thru the exhaust. Unfortunately i have the same problem, but I have a 94 gsr with 126K and I beat the **** out of it....after 6 grand the blue smoke starts to show its ugly face. OEM rebuild and prep for 7 pounds this spring You should just go in there and request a longblock, don't get the run around by those guys.....demand to see the head manager of the service dept. and tell him what the deal is, you paid mad dough for that car and if you haven't beaten the bloody hell out of it, they OWE you a new motor, just my 2 cents
Old 12-20-2002, 08:09 AM
obd2gsr's Avatar
hope the dealer keeps a log and fixes your problem.
by the way, did you guys break in your engines using regular non-synthetic motor oil?
Old 12-20-2002, 08:37 AM
mickey513's Avatar
Sounds to me like the engine wasn't broken in properly. This is one of the symptons or problems of a engine not broken in properly.
Old 12-20-2002, 08:58 AM
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (mickey513)
I broke mine in with regular oil , thats what came in the car. I started having the problem from the beginning. I took it to a different dealership and they tried to tell me it was the crush washer on the oil plug. (total bs) After a while i just thought honda motors liked to burn oil, especially when you run them hard. I have not been easy on my car, but i thought it last more than 80,000 miles.
Old 12-20-2002, 09:02 AM
JL 74's Avatar
After over four years and 45k miles, I never had to add make up oil in my 98 GSR. I drive it hard once in a while and check the levels at least twice a month. Now, I am beginning to think that is weird if the rest burns oil.
Old 12-20-2002, 09:45 AM
New User
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (jl74)
I purchased this car with 13 miles on it. I broke it in textbook perfectly. I used conventional oil until 10,000 miles, then switched to Mobil 1.
I don't redline the engine, ever. If I do push it, I rev to 7800rpms, then shift. I rev-match when shifting, change the oil every 3000mi (with synthetic) and check all fluid levels and tire pressures. If I checked the oil level once a month, I would be running on almost empty oil.
Honestly, I'm getting tired of the oil consumption. Supersyn isn't cheap. Hopefully the dealership will do the right thing.
and give me a JDM longblock; less tolerances for error
{add}This car does see the occasional autocross or canyon run (the main reason why I modified my car). This consumption is whether I'm flogging the car or driving highway miles.
[Modified by 5-SpeedFreak, 10:49 AM 12/20/2002]
Old 12-20-2002, 10:56 AM
SonicGSR's Avatar
Hope they fix the problem!
Old 12-20-2002, 11:44 AM
Buckshot's Avatar
vnt
same here but i have 94k miles and i use mobile 1 also...i had 10w 40 in the summer but for winter to swited to 5w 30 and it seems to be useing a lil more...
Old 12-21-2002, 07:36 PM
ragejed's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (Buckshot)
just dumped a quart of supersyn 530 in mine..only 1700 into my oil change
Old 12-21-2002, 07:51 PM
teggy98's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (ragejed)
My '98 GSR burns about 1.5 quarts between oil changes, I brought it in while under warrenty but the bastards weren't hearin nothin' because I didn't pay them $35 to change the oil every time. I've just learned to live with it. I drive it hard, and I doubt the origional owner was smart enufght to break it in properly.
Old 12-21-2002, 09:24 PM
01SilverGSR's Avatar
I actually have the same problem, but not as bad. I usually have to add a 1/2 a quart every 1 to 2 months. I also use Mobil 1 synthetic. With my car, if I have my A/C on recirculating and after I push it real hard, I can actually smell something through the vents. It's kind of a burning smell but not really. I have no leaks and no smoke out that back at any RPM. So I have no clue.
My car had 55 miles on it when I picked it up, so I don't know if it was broken in properly. I broke it in anyway though.
Old 12-21-2002, 10:15 PM
my96GSR's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (01SilverGSR)
I have the same exact thing happening to me. I have 88k and no smoke or anything, but when I push it I get that smell. I have looked freaking every where and I can't find it.
Old 12-21-2002, 10:28 PM
jeebusm3's Avatar
i go through 1/2 quart every 2500 miles...and i drive hard.
Old 12-22-2002, 07:40 AM
Stewie's Avatar
Default Re: Oil consumption, 2001 GSR.... Went to the dealership today (gtravsr)
dealers rebuild. They don't even make integra engines anymore
Quick Reply: Oil consumption, 2001 GSR.... Went to the dealership today
