Will a 215/50/15 go on the oem 15x6 teg wheel?
Old 06-05-2003, 01:47 PM
stegs's Avatar
Default Will a 215/50/15 go on the oem 15x6 teg wheel?
Does it rub, or cause any wierd issues? Would appreciate your help.
Old 06-05-2003, 03:40 PM
Tweakmeister's Avatar
Default Re: Will a 215/50/15 go on the oem 15x6 teg wheel? (stegs)
probably wouldn't fit the wheel. I know most shop have a hard enough time fitting 205 Azenis.
in terms of rubbing, I don't know. but wheel spacers are fairly cheap.
Old 06-05-2003, 03:56 PM
tegasaurus's Avatar
Default Re: Will a 215/50/15 go on the oem 15x6 teg wheel? (Tweakmeister)
no they wont.
on my 215 azenis it says "DO NOT MOUNT IN 6.5" WHEEL" so it leads me to think, "why would they mount it on a smaller wheel?"
-ryan
Old 06-05-2003, 04:29 PM
95 integra's Avatar
Default Re: Will a 215/50/15 go on the oem 15x6 teg wheel? (tegasaurus)
Just some food for thought, the accord(94-97) mounts a 195 on a 5.5" wheel. I still wouldnt go over a 205 on the stock 15X6s.
Old 06-05-2003, 04:55 PM
mr.beeks's Avatar
they will stick out
about 1.5 on each side of the rim and might rub.
Old 06-06-2003, 04:58 AM
stegs's Avatar
curse acura for only doing 15x6, would probably work with a 15x7 and the proper offset.
Has anybody actually tried it?
Old 06-06-2003, 06:00 AM
n0 iNTegRiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stegs &raquo;</TD></TR><TR><TD CLASS="quote">Has anybody actually tried it?</TD></TR></TABLE>
Haven't tried it. Wouldn't want to try it.
Old 06-06-2003, 07:23 AM
deepgreengsr's Avatar
Default Re: Will a 215/50/15 go on the oem 15x6 teg wheel? (RAF LTD. 2)
okok no more hearsay. Yes it will fit!! how do i know this. well I run 225's on my integra. I have stock wheels (15x6) on my DC2. and I run yokohama a008r's as my race rubber. They are 225/50/15 they do rub a little under full turn and full roll. but at the track I never turn the wheel past 1/2 ish so its all good. on the street I run 205 50 15's and they are a nice street option to.
Go with the 215's!!!
Old 06-06-2003, 10:06 AM
stegs's Avatar
Default Re: Will a 215/50/15 go on the oem 15x6 teg wheel? (deepgreengsr)
Thanks for the input. I say I would have to agree, it 'will' work.
I have successfully run a couple sets of 215/45/16 with my volks during racing. It does rub a little at full lock when parking, (but then who gives a ****).
Follow me through this:
So if the 215/45/16 fits
(8.5" wide, by 23.5" tall),
and deepgreengsr runs the 225/50/15
(9.1" wide, by 23.7" tall) on his oem wheels,
then I could stand to run the slightly smaller, 215/50/15 as its dimensions are only (8.9" wide by 23.5" tall)
Only downers are there aren't alot of tire choices in the 215/50/15 size, tire rack has the sp5000 in that flavor for $108 each. I've had the 205/50/15 in the sp5000, they are decent, just too short and spin to easy, at only 23". That's the reason I am considering the taller tire. The extra width will be money as well.
btw, I also checked specs on the tire rack....the 225/50 that deepgreengsr runs are absolutely approved for a 15x6 rim.
Old 06-06-2003, 08:48 PM
Bill Hook's Avatar
It depends on the tire. TireRack has a "spec" page for each tire model they sell that lists rim size ranges for each size of the model (as you've found out).
Also, 20mm is just a bit over 3/4", total width difference, though I expect having about ~750lbs per corner resting on them when mounted will bulge them some. I think TireRack has info on this width proportion difference for given rim sizes.
If you were going to mount these b/c you wanted to match the 23.3" diameter of stock tires, then don't worry, as not all tires in a any given size actually have the same diameter. The new AVS ES100s are a near perfect match to the 195/55/15 XGT V4s in 205/50/15. S-03s are pretty close as well.
Old 06-06-2003, 09:19 PM
Dee
Dee's Avatar
Default Re: Will a 215/50/15 go on the oem 15x6 teg wheel? (Bill Hook)
ADVAN A048 215/50-15 on 15x6.5 wheels. This setup is flush with the fender because if the centerlock adapter and 5mm spacer (about a 48mm offset).
Old 06-09-2003, 05:26 PM
96dc2's Avatar
Default Re: Will a 215/50/15 go on the oem 15x6 teg wheel? (Dee)
I once had 225/50 BFG Drag Radials mounted on stock 15x6 GS-R rims. So yes yours will fit. Yes, they rubbed on full lock, especially on left turns. Here is how they compared to 205/50's.
GoLowDrew
03-17-2009 10:40 PM
broketuner-Sol_Si
03-11-2007 08:06 AM
Lo-Buck EF
04-21-2006 02:55 PM
K20EF8
10-05-2005 06:38 AM
BIGBLOCKEK
13
11-21-2004 02:10 PM
Quick Reply: Will a 215/50/15 go on the oem 15x6 teg wheel?
