OEM Type R wing onto GSR - Honda-Tech
Old 06-16-2008, 12:32 PM   #1
Default OEM Type R wing onto GSR
Hi guys I'm putting an OEM type R wing onto my gsr and would like to know if I have to pick anything up from the dealership to install it correctly. Will I just be reusing the same screws from my gsr spoiler? Thanks for your help!
IntegrasAreBest is offline   Reply With Quote
Old 06-16-2008, 12:35 PM   #2
walker111's Avatar
Default Re: OEM Type R wing onto GSR (IntegrasAreBest)
Quote:
If its a new wing everything should come with it.... double sided tape, and 4 ten mm nuts.
walker111 is offline   Reply With Quote
Old 06-16-2008, 12:41 PM   #3
no I bought it off of jdm frontin a while ago and just got around to painting it. Thanks, I'll head to the dealership now and get what you mentioned from them.
Old 06-16-2008, 12:51 PM   #4
Collector-o-Guns and Drinker
Splat's Avatar
Default Re: (IntegrasAreBest)
Don't GS-R's have an extra hole for the brake light wiring? Not sure if that will show after install or not.
Splat is offline   Reply With Quote
Old 06-16-2008, 12:55 PM   #5
yeah theres going to be a visible whole, im going to home depot to buy a plug for it.
Old 06-16-2008, 02:25 PM   #6
get RIGHT's Avatar
Get the double sided tape from your Acura dealer. If you dont use it you will get paint damage on your decklid when you torque the wing down.
get RIGHT is offline   Reply With Quote
Old 03-12-2009, 02:23 AM   #7
poppypizza's Avatar
Quote:
did u get those plugs? how does it look? any pictures?
poppypizza is offline   Reply With Quote
Old 03-12-2009, 06:08 AM   #8
Kite's Avatar
Quote:
Yup, I really wish the previous owner of my GSR would have used some when they mounted the horrible whale tail wing on there . Oh well, trunk will be fixed soon enough.
Kite is offline   Reply With Quote
Old 04-10-2009, 12:38 PM   #9
suzawa94's Avatar
i have the same dilemma. anybody?
suzawa94 is offline   Reply With Quote
Old 04-10-2009, 02:09 PM   #10
FearDisH22a4's Avatar
theres actually going to be 2 holes visible. go to home depot and get some nylon plugs. 7/8 for the passenger side hole and 7/16 for the driver side hole. you also might want to use a little bit of clear silicone on the outer edges of the plugs to keep water from getting in the holes. this is the info i found while researching on team integra. ima be replacing my wing soon also.
FearDisH22a4 is offline   Reply With Quote
Old 04-10-2009, 02:32 PM   #11
SPOOLINmatt's Avatar
i wouldn't do it if there was going to be holes visible...plugs or not
SPOOLINmatt is offline   Reply With Quote
Old 04-12-2009, 01:58 PM   #12
suzawa94's Avatar
Quote:
thanks for the info. i just seen that thread on ti also. i picked up those plugs and some other things that look like they might work...
Old 04-13-2009, 04:50 PM   #13
zachv365's Avatar
I'm glad I came across this thread, I just took my gsr wing off and am about to replace it with a type r wing also. I will have to have my paint guy shave those holes cuz I had no idea. Speaking of, GSR stock black spoiler fs or trade for type r wing plus cash.
zachv365 is offline   Reply With Quote
Old 05-02-2009, 10:38 AM   #14
milanoteg's Avatar
good info.
How hard is it to fill in the visible holes? I'm assuming it'd involve welding a new piece of metal in? Anyone try this?
milanoteg is offline   Reply With Quote
Old 05-02-2009, 12:14 PM   #15
tbsol's Avatar
I welded in the holes on my GSR hatch..
There is one big hole from GSR spoiler light wiring (~1") and a smaller one for one of the mounts (~3/8") if I remember correctly. Welded in a patch to fill the holes..
IMO weld them over just putting plugs in... it looks a lot cleaner and you don't have to worry about rusting etc.
Also, don't forget that you also loose your 3rd brake light. You might want to pick one up from a RS or something....
tbsol is offline   Reply With Quote
Old 05-02-2009, 12:18 PM   #16
They let me pick
mrdeadman's Avatar
If you get the ITR replica from spoilerdepot, the holes are covered...
mrdeadman is offline   Reply With Quote
Old 05-02-2009, 01:50 PM   #17
BoltonGSR's Avatar
I took off my stock spoiler and just put electric tape over the holes haha. Works fine, no leaks...
BoltonGSR is offline   Reply With Quote
Old 05-02-2009, 04:42 PM   #18
civicdreamin's Avatar
Kinda sucs for you guys a little that have the oem gsr spoiler.. i bought my db8 wingless and slapped a type r wing on perfect.. honda even had the spots to drill under the trunk..
civicdreamin is offline   Reply With Quote
Old 05-02-2009, 11:28 PM   #19
milanoteg's Avatar
^ Yeah Im debating on whether or not I should weld these holes or buy a new wingless hatch to install the ITR wing
Old 05-03-2009, 08:23 AM   #20
my wings west replica type r wing with third brake light in it covered the holes.
purplevtec2000 is offline   Reply With Quote
Old 05-03-2009, 11:57 AM   #21
milanoteg's Avatar
I dont like the replica's.
Does the OEM ITR wing use the same holes as the GSR holes? Obviously some of the holes will be left uncovered, but do I have to drill any new holes for the oem ITR wing?
Old 05-03-2009, 09:30 PM   #22
tbsol's Avatar
Yeah it uses the same bolt holes.. the GSR just has a few extra's.
You don't have to drill any holes to mount an OEM ITR spoiler onto a GSR hatch.
Old 05-03-2009, 10:20 PM   #23
nyrican23's Avatar
Just use colored vinyl to cover the holes
nyrican23 is offline   Reply With Quote
Old 05-04-2009, 09:03 PM   #24
ivan93egreppin210's Avatar
will the oem type r wing bolt up to ls trunk holes?
ivan93egreppin210 is offline   Reply With Quote
Old 05-05-2009, 04:12 AM   #25
I just wanted to know what your doing with your stock wing and what year yours is?
92AcuraGSR is offline   Reply With Quote
mugen 1st gen wing ChiLS Acura Integra 1 01-03-2009 07:35 PM
cosmetic questions DC5mike Acura RSX DC5 & Honda Civic EP3 2 11-20-2007 01:10 AM
How to tell if a type r wing is real OEM? bo0sted Acura Integra Type-R 6 04-03-2003 07:25 AM
WTT: gsr wing for type-r wing move_right For Sale 8 03-03-2003 08:02 AM
integra type R wing? Skunk_it Acura Integra 3 10-10-2002 09:29 PM
Tags
92, acura, eing, gsr, install, integra, itr, oem, rear, spoiler, trunk, type, typer, wing, wingless
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
