oem rings and piston ?
Old 12-15-2002, 12:45 PM
98civicEX's Avatar
Default oem rings and piston ?
i have usdm itr pistons and rings directy from honda, and the oil ring seems to be getting stuck when i'm putting the piston in the block. yes, i'm using a piston ring compressor...but it still gets caught...are the rings don't need to be shaved correct? they're already set to spec?
Old 12-15-2002, 01:39 PM
TRuST's Avatar
Default Re: oem rings and piston ? (98civicEX)
Is the oil rings on correctly ? If they are what I did was first oil the cylinder and the piston so that it slides in easier.
Old 12-15-2002, 02:06 PM
Cjsls's Avatar
don't know if this'll help ya but anyways......i know some guys who when tapping the piston into the block don't just tap the middle of the piston until its in(although most of the time this works very easily), but they tap one side of the piston then start tapping along the edge going in a circular pattern until the piston is in the bore.
benin360
11-26-2011 09:20 PM
Crash2474
11-21-2011 04:40 PM
forsakenriceboy86
11-29-2009 09:08 PM
maka
04-06-2004 07:03 AM
Aeka GSR
09-28-2003 11:15 AM
Quick Reply: oem rings and piston ?
