Which OEM clutch?
Which OEM clutch?
I need to replace the clutch in my LS. I need to stay with a OEM grade clutch because of my autocross class. I have read good things about the OEM Exedy kit (KHC05) but, also ran accross the Competition Clutch OEM kit. Does anyone have any experience with the Competition Clutch kit as a comparison to the Exedy kit?
Re: Which OEM clutch?
EXCEDY FOR SURE !!!!!!!! i had such a great experience with the Excedy stage 1 organic clutch believe me the engagement was great and never complained about it i lov to run canyons and it never gave me a problem at all and held up well also its slightly stiffer than OEM i highly recomend it !!!!!!!!!
exedy or fuji carbon, the exedy is half the price. only difference between the two is the fuji has a slightly stronger pressure plate which you'll feel in the pedal.
for a stock ls, get the exedy oem. the clutch disc is what you're going to trash doing autocross. if it's legal the stage 1 would be ideal since it has a reinforced disc and much stronger pressure plate
TypeSH
03-21-2002 02:23 PM
