OBD2 GSR IAB wiring
Old 10-21-2010, 11:41 AM
Rok_Stok's Avatar
Default OBD2 GSR IAB wiring
I have a '94 Civic Si and am putting an OBD2 GSR engine and ECU in it. I would run an OBD1 ECU but the OBD2 engines don't have VTEC pressure switches, so an OBD1 ECU would have a CEL and not engage VTEC. So I'm just going to use a jumper harness and run the OBD2 ECU.
I know how to wire the IAB for an OBD1 ECU by using the EVAP solenoid plug and put the pin (A20) in the IAB position (A17), but I'm guessing the pins are different on an OBD2 ECU. Can anybody give me info on the OBD2 GSR ECU?
Old 10-21-2010, 12:17 PM
bigkvn77's Avatar
Default Re: OBD2 GSR IAB wiring
http://hondaswap.com/reference-mater...pinouts-28667/
Old 10-21-2010, 02:40 PM
komat's Avatar
http://www.xenocron.com/install/OBD1-IABs.htm
Old 10-21-2010, 04:51 PM
Technical Hero
HondaPartsHero's Avatar
All u need to do is screw in a pressure switch,check my sig below if you need one or a harness for your swap
Old 10-22-2010, 09:52 AM
Rok_Stok's Avatar
The OBD1 to OBD2 wire harness just directs the pins to the new location right? So for IAB I should be able to put the evap pin into the iAB location (A17) on my OBD1 harness and the jumper harness does the rest right?
Old 10-22-2010, 03:04 PM
Phat4Door's Avatar
i believe you will run into the problem of you will need your crank position sensor hooked up, the random sensors on the obd2 manifold up top hooked up, and also some sensors associated with your charcoal canister hooked up as well, so it is extra hassle, use the obd1 ecu, and drill and tap where the pressure switch goes to, not too hard, just do it off the motor....
Rok_Stok
10-21-2010 01:06 PM
trevek10
09-18-2009 06:43 AM
trevek10
09-17-2009 05:28 PM
recon23
07-17-2009 09:31 PM
screen_name
04-22-2006 06:56 PM
Quick Reply: OBD2 GSR IAB wiring
