OBD1 Distributor Wiring Diagram
Old 01-13-2009, 04:58 PM
vietnamezerice's Avatar
Default OBD1 Distributor Wiring Diagram
need it
Old 01-13-2009, 05:30 PM
Romo Pyro's Avatar
Default Re: OBD1 Distributor Wiring Diagram
Hope this helps
http://www.phearable.net/tech/wiring...istributor.jpg
Old 01-13-2009, 05:34 PM
a little bit... but the OBD1 plugs have alot more wires
Old 01-13-2009, 05:37 PM
here's a picture from that link... doesn't anyone know if there's voltage going through the yellow/green wire? (ICMMMM)
Old 01-13-2009, 06:19 PM
HONDAPARTSMANMIKE's Avatar
here a diagram of an obd1 dizzy. hope this helps
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Last edited by HONDAPARTSMANMIKE; 01-13-2009 at 07:54 PM. Reason: added more attachments
Old 01-13-2009, 06:45 PM
thanks man does anyone know if there's voltage for the input signal wire though?
Old 04-14-2010, 08:54 AM
h22a7-crx's Avatar
hey , wanna ask if u can help me wiring an obd1 dizzy to h22a7 obd2b . thx
Old 01-14-2020, 04:14 PM
Kenneth123r's Avatar
Ok so I have a 2000 honda civic that i put a 98 head on and need to know how to wire in the distributor???????
Old 01-15-2020, 04:00 PM
wunfstgsr's Avatar
You just bumped a 11 year old thread! You should start your own, and FYI just use a conversion harness for the Dizzy.
vectorsolid
08-06-2012 12:35 PM
civickid03
10-06-2008 02:23 PM
Quick Reply: OBD1 Distributor Wiring Diagram
