what swaps into a first gen easily?
Old 08-08-2004, 08:04 PM
forrest's Avatar
Default what swaps into a first gen easily?
Sorry for the newb question...I'm new to this forum and these motors, but not to racing. I've got an 88 integra that is my track car. It is gutted with an autopower race cage/tokico adj. front and rear. susp. techniques front and rear sways, I/H/E, etc. The old D16 DOCH motor finally gave up on me after 215K. I am wondering what my options are. I know I can swap in another d16, but I was looking for more than that. How about a b16 or a newer LS motor. These are motors I can get cheaply where I work. Any info or links would help.
Thanks
Old 08-08-2004, 10:48 PM
forrest's Avatar
Default Re: what swaps into a first gen easily? (forrest)
I have used the search function...but does anyone else have any info??
Old 08-09-2004, 09:06 AM
forrest's Avatar
no one else knows???
Old 08-09-2004, 09:16 AM
purplegsr's Avatar
https://honda-tech.com/zerothread?id=759125
https://honda-tech.com/zerothread?id=617744
https://honda-tech.com/zerothread?id=476221
try http://www.g1teg.org and http://www.hybridgarage.com
You can basically put any B-series motor in it, as long as you get the correct engine mount kits from Hasport, or figure out your own.
Old 08-09-2004, 09:19 AM
forrest's Avatar
Default Re: what swaps into a first gen easily? (purplegsr)
Truly appreciated.
you are a gentleman and a scholar
Old 08-09-2004, 09:28 AM
purplegsr's Avatar
No problem, good luck with the project. Sounds fun.
I would get the B16 over the LS, especially if you can get it for cheap. The B16 has less torque, more hp, and vtec of course - however, for either of those setups (LS or B16), you would need a new tranny, since a D-series won't work with a B-series. The B16 tranny would be better than the LS (LS has veerrrry long gearing) in your case. If you didn't want vtec, you might try to get an LS (more torque, less hp) and match it with a B16 tranny.
Either way, your car is pretty light and would probably be noticeably quicker with either setup.
E-Town4229
10-04-2012 10:48 AM
digital sol
11-22-2005 07:37 PM
crxsi541
02-25-2005 10:10 PM
teamrpmTN
12-18-2004 05:38 PM
dirtcop0007
06-05-2004 11:23 AM
Quick Reply: what swaps into a first gen easily?
