noise when turning steering wheel - Honda-Tech
Old 02-08-2009, 08:03 AM   #1
VTECdohcter's Avatar
Default noise when turning steering wheel
ive had this clicking noise for a while every time i turn the wheel to either side and i cant figure out what it is any help?
VTECdohcter is offline   Reply With Quote
Old 02-08-2009, 09:35 AM   #2
DcLs's Avatar
Default Re: noise when turning steering wheel
i just had this problem, its your axel. find out which side it is and replace it asap
DcLs is offline   Reply With Quote
Old 02-08-2009, 04:21 PM   #3
not sayin i dont believe u but how positive are u its my axle ima take a look in the mornin
BUMP!!!
Old 02-08-2009, 04:26 PM   #4
paton5g's Avatar
He's positive and so am I.
The CV boot has cracked, leaking all the grease. The CV joint has then been run dry for some time and is now clicking because it's not lubricated and damaged. If it's clicking on both sides, you'll need two new axles. Yes it sucks. Good luck.
paton5g is offline   Reply With Quote
Old 02-08-2009, 04:37 PM   #5
The problem lies in your axle(s). Don't launch or do a burnout, it will snap. (like mine did)
stock88crx is offline   Reply With Quote
Old 02-08-2009, 04:46 PM   #6
sp00ledbseries's Avatar
like all them said it is your axle. figure out which one and replace it
sp00ledbseries is offline   Reply With Quote
Old 02-08-2009, 08:34 PM   #7
integragsssr's Avatar
Quote:
Originally Posted by stock88crx View Post
the problem lies in your axle(s). Don't launch or do a burnout, it will snap. (like mine did)
x2
integragsssr is offline   Reply With Quote
Old 02-09-2009, 07:09 AM   #8
PatrickGSR94's Avatar
How about we get some more information from the OP before everyone just up and proclaims "it's the axle!!!11!!!one!!eleven"
OP: does the clicking sound occur while driving (turning a corner)? Or does it happen while the car is sitting stationary and you turn the wheel? If the former, then it's the axle like everyone said. If the latter, then it's NOT the axle.
If it makes the noise while sitting still and turning the wheel, then the problem could be the steering rack itself, but more likely it's one of you ball joints. My car had this very problem and I thought I traced it to the steering rack. I replaced the rack with a rebuilt unit, but the problem remained! Finally I found the left lower ball joint boot was all torn, grease had all come out, and all kinds of dirt and grit were in there. I had that ball joint replaced and it fixed the problem right up.
PatrickGSR94 is offline   Reply With Quote
Old 02-10-2009, 08:03 AM   #9
it happens while i drive while im stopped all the time thanx for everyones help but need to get this resolved
Old 02-10-2009, 03:35 PM   #10
i checked the boots today and both on both sides arent leaking grease
Old 02-10-2009, 04:07 PM   #11
If it happens while stopped, it's most likely NOT the axles. Check the upper and lower ball joints.
Old 02-10-2009, 04:46 PM   #12
I have the same issue and the sound is comin from the power steering ram, NOT THE AXLES, everyone jumps straight to the axles all the time, but u need to be specific when asking for help...
Pimpsherm2009 is offline   Reply With Quote
Old 02-10-2009, 05:10 PM   #13
bump!!! how do i tell if the ball joints are bad?
Old 02-10-2009, 06:37 PM   #14
They usually have grease coming out and the ball joints boots will be torn, also they will be makeing noise and worn
Old 02-10-2009, 06:46 PM   #15
check the power steering sys fluid and total sys too
Old 02-10-2009, 06:52 PM   #16
GSE980's Avatar
if its a clicking then its your axle........jack your car up and check the boots
if its a winding noise there is probably air in your P.S. system
Also, correct me if I am wrong I thought the P.S. was just a pump that helped assist the rack and pinion. Not a hydraulic ram moving the steering ?? Im not to sure how it works down there I never really got into steering systems PRETTY BORING
GSE980 is offline   Reply With Quote
Old 02-11-2009, 06:20 PM   #17
Bump!!!
Old 02-11-2009, 07:35 PM   #18
Did you read what I posted above? If the noise happens when the car is stopped, it is NOT the axle.
Old 02-12-2009, 07:38 AM   #19
yes i read ur post just i have 3 different people telling me different things
Old 02-12-2009, 10:18 AM   #20
If it is happening while car is stopped then it is either the ball joints or tie-rods. You can check the ball joints by jacking up on the lower control arms and lifting up on the bottom of the tire with a pry bar. To check the outter tie rods grab them anpush upward and down ward to check for looseness. The inners are the same but there will be a boot on the rack you have to squeeze down to feel the tie rod.
NitroB18c1 is offline   Reply With Quote
Old 02-12-2009, 10:19 AM   #21
One more thing make sure you sway bar links are still in one piece.
Old 02-12-2009, 01:45 PM   #22
JDMDA9G4's Avatar
Its the outer cv joint(fixed)closer to the wheel
if it was the inner it would make a clunking noise
JDMDA9G4 is offline   Reply With Quote
Old 02-12-2009, 02:04 PM   #23
1SicLS's Avatar
are we sure its not in the steering column how loud is the clicking
1SicLS is offline   Reply With Quote
Old 02-14-2009, 07:49 PM   #24
Dude listen to me dude these guys keep telling you to look at ur CV joints, but you said they look good right. Look at the ball joints or the tie rode ends(inner or outter).
Old 02-14-2009, 08:50 PM   #25
For the third time, the OP said it makes the noise while the car is stopped (as well as while driving), therefore it is NOT the axles!
Also, inner CV joints vibrate under load when they go bad. I've never heard of one making a clunking noise.
Wheel Bearing gone bad? chanelton Suspension & Brakes 3 06-04-2010 12:50 PM
annoying noise, dohc_profile Acura Integra 5 06-04-2007 02:49 PM
weird noise? axle? whp Honda Prelude 3 02-03-2007 09:08 AM
noise from engine block? eseries07 Honda Civic (2001 - 2005) 1 09-27-2006 12:31 PM
annoying popping noise tinamina Honda Civic / Del Sol (1992 - 2000) 10 02-26-2005 05:07 PM
Tags
acura, clicking, fit, honda, leaking, noise, pinion, rack, sounds, steering, system, tl, tsx, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
