Need Some advise
Old 01-14-2015, 06:32 PM
potatointegra01's Avatar
Default Need Some advise
I have a b18b ls motor and I'm am gonna turbo but not yet.. But I want the most power out of my car before I turbo. So is their any way I could get more power without turbo or lsv? Like will cams, valve springs do it?( yeah I'm am gonna be changing the rods and cylinders to forged) And also what could make my car rev higher than just 7k?
Old 01-14-2015, 06:49 PM
B_Swapped93's Avatar
Default Re: Need Some advise
VTEC is a must the heads flow so much better, along with many other advantages so keep that in mind. 2nd "more power before the actual turbo set up"... most comes along with the turbo but what I did was get an ultra series manifold an 74mm tb other then that everything will be replaced. 3rd cams a set of ITR cams will do great for sub 400hp range and are pretty cheap upgraded valve springs will be needed to rev higher. 4th those aftermarket pistons/rods you plan on determine that along with other factors you do realize you're going to be into the high $8000+ range now right.
murtnabila
07-26-2005 08:53 PM
redDAinteg
04-30-2005 02:10 PM
InfamousRS
09-10-2004 02:17 PM
wade
06-21-2004 07:18 AM
dominate9
02-03-2004 12:56 PM
Quick Reply: Need Some advise
