Need to know what rear motor mount I need (HELP)
So I purchased a DC2 and it looks nice but has so much **** wrong with it it's got my brain hurting.
Basically, for some reason the previous owner has removed the power steering rack and sub frame and replaced it with a manual rack and 96-00 civic sub frame ( I know it has a crap turning speed over the EG/DC2). Not sure what made them pick the EK sub frame and not just use an EG if they wanted to go manual rack. I noticed when I was cleaning things up in the engine bay that the rear bracket was not bolted to the motor mount and that it looked like the wrong bracket or mount. This is what got me looking at the sub frames.
Anyways, I figured out that I needed the 99-00 Civic Si rear bracket b/c the DC2 was to long and passed the bolt hole for the mount. Now, I don't really know if I have a EK civic mount or a DC2 motor mount on there. In any case the motor mount is trashed and I'm replacing it with a new one.
I need to know which motor mount I need before I make the purchase. I'm assuming that I need to get the mount that matches the rear bracket (99-00 Civic SI). I can get an Integra mount easy from the junkyard but a SI mount is harder to come by. I'm I correct in thinking I need the SI rear mount?
Thanks for any help. Eventually I will swap in an EG sub frame so I can get the better performing manual rack on there.
-Ryan
-Ryan
Re: Need to know what rear motor mount I need (HELP)
the rear "mounts" are the same afaik the "T bracket" however is different, you're after the t bracket a $60 part at Honda...look at a diagram for the part number. One thing to keep in mind the rear mount holds the engine up for the most part, if that is trashed and there were no bolts in the "t bracket" it may see as if it's the wrong one. replace the rear mount first then see, if you need the bolt part number look here Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland
Yeah I bought the civic si bracket and after looking at Hasports website, I realized that the mounts were the same. Going to hit up the junk yard and see if I can find one from a manual civic. Or I might just get a Hasport kit.
solid mounts were the best purchase I made, they make such a difference the car just feels firmer.
H-T Premium Sponsor
auto and manual rear mounts are the same. all 92-00 civic rear mounts and 94-01 integra rear mounts are interchangeable
Brandon H.
02-16-2013 06:31 PM
95dc2teg
05-01-2007 10:35 PM
AzntaggeR
02-14-2004 07:31 PM
Civichatch972
12-08-2002 11:42 AM
