need help quick..climate controll...did search no good results
need help quick..climate control...did search no good results
i cant seem to remove my climate control, one of the bulbs back there is blown and i got a new one for it , im pushin and pulling at it and it wont pop out...any advice?
Re: need help quick..climate control...did search no good results (J337_UNIT)
did u remove the hazards and defrost buttons and get the screws behind those ?
If you look under the dash on the passenger's side, you will see the heater cable which you remove first. Then you pop off the rear defrost and hazzard button, and remove the two screws under there. Next you pull the climate control out a little, and reach behind to unplug the two harnesses behind it, and the entire unit can then be removed
i tried popping off the hazard button and i saw a bulb back there , no screw... am i looking in the right place?
Modified by J337_UNIT at 7:18 AM 6/9/2003
preludepower
10-14-2005 09:17 PM
ner0x
06-23-2005 07:17 PM
Tomek
10-05-2002 05:46 AM
