NEED help!!! piece of dipstick broke off into engine.. b18b1 - Honda-Tech
Old 11-30-2010, 12:39 PM   #1
MdMaxPluR's Avatar
Default NEED help!!! piece of dipstick broke off into engine.. b18b1
ok so i havent checked my oil for awhile. so i decided to check it today and i find out that something broke off the dipstick where the 2nd dot is at. its broken like 1 1/2 inch off the dipstick. im wondering will my engine get messed up with that little peice floating around.? its driving fine and runs fine. about 1 month ago when i pulled the dipstick it was bent about 2 inches. what can possibly be breaking/bending my dipstick in the engine? thanks
MdMaxPluR is offline   Reply With Quote
Old 11-30-2010, 12:44 PM   #2
vrrodri's Avatar
Default Re: NEED help!!! piece of dipstick broke off into engine.. b18b1
Maybe it wasn't the original dipstick?
vrrodri is offline   Reply With Quote
Old 11-30-2010, 01:33 PM   #3
MdMaxPluR's Avatar
lolz found the problem. freakin nephew borrowed my dipstick to check his oil.... ahahaha
Old 11-30-2010, 05:40 PM   #4
wunfstgsr's Avatar
slap your nephew in the back of his head! lol that piece is gonna blow your motor up dude!!! jk it will eventually float down and hopefully drain out in your next oil change!
wunfstgsr is offline   Reply With Quote
Old 12-01-2010, 09:48 AM   #5
vrrodri's Avatar
Maybe installing a magnetic drain plug might catch it before it is too late, otherwise take the oil pan out and retrieve that POS...
Old 12-01-2010, 02:32 PM   #6
mouab18c1's Avatar
Quote:
SLAP HIM!
mouab18c1 is offline   Reply With Quote
Old 12-01-2010, 02:46 PM   #7
Sounds like Jimmy wasn't thinking with his dipstick!!
SkidmarkEH2 is offline   Reply With Quote
Old 12-02-2010, 02:45 AM   #8
Prozon's Avatar
Are you saying your dipstick is still broken in the engine- that your nephew did it?
Or just that he borrowed your dipstick and put his broken one in?
If it's in your engine I suggest dropping the pan. Or slapping a powerful magnet to the bottom of the pan.
Prozon is offline   Reply With Quote
D16Z6 oil dipstick comes up dry - Where did the oil go? k20eklipse Honda Civic / Del Sol (1992 - 2000) 13 10-24-2010 08:19 PM
oil dipstick might be wrong. dansaleen_04 Honda Accord (1990 - 2002) 11 10-19-2010 06:42 PM
dipstick reads no oil. LS VTEC ... help turboman2.2 All Motor / Naturally Aspirated 7 04-21-2010 04:46 PM
Dipstick tube & Dispstick length on B18 vs. B20? nickzed20 Acura Integra 0 08-13-2006 03:24 PM
Dipstick help needed. Please respond 311 Honda Civic / Del Sol (1992 - 2000) 11 08-19-2004 06:17 PM
Tags
acura, antoniotx, broke, broken, dip, dipstick, fit, honda, integra, issue, oil, part, parts, san, stick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
