Need help with ngk sport plug wires
Old 08-29-2004, 03:00 PM
Innovative LS's Avatar
Default Need help with ngk sport plug wires
I have a set of the Beru Silverstone spark plugs (nology) and I am using the Ngk sport plug wires (Blues) and top of the Beru plugs came off in the plug wires. So I purchased the Ngk v power plugs and replaced the Beru plugs but I had to use two of the original OEM Sumitoma plug wires and noticed that the OEM wires had clean boots while the ngk plug wires had lots of black and brown dust on them as well as the Beru plugs. Then while installing the plug wires I noticed that the OEM wires were seating better to valve cover. I was wondering if the the lack of seal on the Ngk plug wires where contributing to the dust accumulation or if the dust was normal wear and tear, and if i should clean spark plug holes? Thanks
Old 08-29-2004, 05:58 PM
Default Re: Need help with ngk sport plug wires (Innovative LS)
bump
Old 08-30-2004, 07:22 PM
bump, anybody?
Old 08-30-2004, 07:30 PM
stumpyf4's Avatar
My NGK wires fit great with the NGK plugs. I think it may be a problem with the Beru plugs. Clean everything and use a bit of di-electric grease on the spark plug boot so the wire doesn't bake itself onto the plug.
Old 08-30-2004, 08:25 PM
Default Re: Need help with ngk sport plug wires (stumpyf4)
thanks, so is the brown and black dust normal
OrangeTeggy
04-04-2009 12:43 PM
Innovative LS
08-30-2004 07:23 PM
wannakno
11-26-2002 08:32 PM
Quick Reply: Need help with ngk sport plug wires
