need help with b18 block
Old 11-08-2006, 07:22 AM
matt c's Avatar
Default need help with b18 block
i killed my motor i have a 99 gsr and i was wondering if i could use a 94 block i have been told i could and i couldent
so if i can what will i have to change
Old 11-08-2006, 07:31 AM
97itypeR's Avatar
im pretty sure u can because i mean...if u can take a b16head and put it on a LS block, wouldnt that be MORE than enough evidence that u can mix and match the years of head/blocks?
Old 11-08-2006, 08:43 AM
95 integra's Avatar
Default Re: (97itypeR)
Yes, you can, you will need to change out the oil pump to be able to hook up the crank position sensor. Other then that I believe the blocks are identical.
Old 11-08-2006, 08:57 AM
POE
POE's Avatar
yes the obd2 has an crank position sensor and the 94 (obd1) doesnt. SO change that and u are good to go
Old 11-08-2006, 08:58 AM
krweby's Avatar
Like 95 integra said the blocks are the same but you will need to change the oil pump so you can hook up the crank sensor.
Old 11-08-2006, 08:59 AM
1997 gsr's Avatar
Default Re: (POE)
its the same size motor. i dont see why u couldnt because like one dude said u can switch up heads with blocks. so good luck
Old 11-09-2006, 10:27 AM
97itypeR's Avatar
thank you i take credit for that head/.block mix :thumbsup:
Old 11-09-2006, 11:56 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itypeR &raquo;</TD></TR><TR><TD CLASS="quote">thank you i take credit for that head/.block mix :thumbsup:</TD></TR></TABLE>
You take credit for what?
Old 11-09-2006, 03:00 PM
GoldCoin's Avatar
Default Re: (95 integra)
i guess he sees <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1997 gsr &raquo;</TD></TR><TR><TD CLASS="quote">its the same size motor. i dont see why u couldnt because like one dude said u can switch up heads with blocks. so good luck</TD></TR></TABLE>
so he wants to say <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itypeR &raquo;</TD></TR><TR><TD CLASS="quote">thank you i take credit for that head/.block mix :thumbsup:</TD></TR></TABLE>
and then your wondering<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">You take credit for what?</TD></TR></TABLE>
but i say i doesnt matter cuz your still helping someone out
FeelinKoopish
04-13-2008 03:18 PM
turbodohcsi
01-10-2005 04:07 PM
Huee
03-01-2004 12:53 PM
riceburnah
05-29-2003 09:30 AM
6pucker
05-26-2002 10:42 PM
Quick Reply: need help with b18 block
