NEED 95 Integra fuse diagram
Im trying to figure out why my cigarette lighter isnt working, so im gonna check the fuses first, i just dont know which fuse it is. Anyone have the diagram for it? Im missing the plastic cover
H-T Order of Merit
Re: NEED 95 Integra fuse diagram (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">You'll find it in your service manual.</TD></TR></TABLE>
It's on pages 23-48 and 23-49 of the '94 service manual.
The cigarette lighter is fuse number 23 and it's a 15 amp fuse. With the hinges at the top, it's the rightmost fuse in the top row. (There's a spare fuse just to the right of it though.)
The service manual doesn't come with the car. If you plan to work on your own car, it's a great thing to have. You can buy one here.
H-T Order of Merit
Re: NEED 95 Integra fuse diagram (v0lcom27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v0lcom27 »</TD></TR><TR><TD CLASS="quote">Thanks a lot man. I checked the fuse, its fine. Whats the next step? new lighter?</TD></TR></TABLE>
Try things that are easy and likely and cheap first.
If you have something that plugs into a cigarette lighter, like a radar detector, cell phone charger, etc, then try that just to make sure there is power to the lighter socket. (Start the car first.)
If there's power, then it's definitely the cigarette lighter, and replacing it is cheap.
However, cigarette smoking makes you sick and eventually kills you, makes you and your hair and clothes stink, and costs a lot of money that you could be spending on other things in your life. So maybe the broken cigarette lighter is just one more reason for you to quit smoking.
Good luck!
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Try things that are easy and likely and cheap first.
Good luck!</TD></TR></TABLE>
Heh, im trying to get it to work so i can use my radar. I plugged it in, and it didnt work.
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v0lcom27 »</TD></TR><TR><TD CLASS="quote">Heh, im trying to get it to work so i can use my radar. I plugged it in, and it didnt work.</TD></TR></TABLE>
Ha ha ha!
Then there's no need to replace the cigarette lighter. If your problem is with your radar detector, replacing the lighter won't do anything.
First, try plugging your radar detector into another car's outlet to make sure it's not the radar detector.
If the detector is working in another car but not this one, then either there's no power in the outlet, or the outlet is bent or something so that the plug can't make contact. Again, try a different device (like a lighter) to test and see whether there's power...
Ha ha ha!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Ha ha ha!
If the detector is working in another car but not this one, then either there's no power in the outlet, or the outlet is bent or something so that the plug can't make contact. Again, try a different device (like a lighter) to test and see whether there's power...</TD></TR></TABLE>
The detector works in everyones car but mine.
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">If the detector is working in another car but not this one, then either there's no power in the outlet, or the outlet is bent or something so that the plug can't make contact. Again, try a different device (like a lighter) to test and see whether there's power...</TD></TR></TABLE>
mcgowanbl
08-02-2020 04:13 PM
j-rome
09-13-2006 11:29 AM
b16a2coupe
07-04-2006 10:48 AM
