over heatin problem
Old 06-09-2005, 04:51 PM
MugenedEJ's Avatar
Default over heatin problem
I got a 92 integra and its over heating.
I have try putting 50/50 in the reservoir and 2 days later its empty. Ive gone though 2 bottles aready.
Ive tried checkin for leak but dont see any at all.
Thanks
Old 06-09-2005, 04:58 PM
Keno20's Avatar
Default Re: over heatin problem (MugenedEJ)
There must be a leak somewhere along the line. Surely?? Have you checked all the hoses? Resoiver? radiator?
Old 06-09-2005, 05:04 PM
MugenedEJ's Avatar
Default Re: over heatin problem (Keno20)
My Resoiver, radiator,is fine, ive checked the radiator hose(upper and lower) and thats fine too.and dont even see a drop on the ground.
Old 06-09-2005, 06:58 PM
Contender25
Guest
Posts: n/a
Had this prob on my moms civic hatchback. I replaced the radiator and radiator cap, and never had a prob again with coolant mysteriously evaporating i guess...
Old 06-09-2005, 07:00 PM
loud_whispers's Avatar
if it's not leaking out of the engine.. then there's a problem.
start the car up and feel the upper rad hose..
If it get's rock hard then you need a headgasket.
that's most likely the case!
97tegGS's Avatar
Leaking any on the ground? Like from the freeze plugs? Any in the oil? Could be bad headgasket if there is some in the oil.
Old 06-09-2005, 07:02 PM
Default Re: (97tegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tegGS &raquo;</TD></TR><TR><TD CLASS="quote">Leaking any on the ground? Like from the freeze plugs? Any in the oil? Could be bad headgasket if there is some in the oil.</TD></TR></TABLE>
unless the headgasket is totally blown to ****, you will not find coolant in the oil by checking the dipstick. you'll find it with the head pulled off with oil in the coolant jackets
Sl0wH0nda
06-13-2013 10:22 AM
dynastix9
12-18-2005 06:33 AM
speedaholic92
05-09-2003 06:07 PM
94acurals
12-05-2001 05:32 AM
Chip398193
09-10-2001 01:12 PM
Quick Reply: over heatin problem
