My Integra GSR Transmission Build/Assembly
Old 03-31-2012, 07:16 PM
No-Traction = Fun
CaliforniaDad's Avatar
Default My Integra GSR Transmission Build/Assembly
HELP
In need of a Competition Clutch Twin Disk clutch for my setup Part#4-8026-C
Ill be switching up to E85 now, so my projected goal is 600-700 WHP
Anyone have one they wanna sell or have any leads on one please let me know!!
David
760-550-7997
Well I thought I would start a new thread on my GSR transmission Rebuild/Assembly. I plan on installing my modified OBX LSD and all new carbon syncros 1 thru 5 all new seals and bearings as well.
Old 04-01-2012, 12:05 AM
guess_who's Avatar
Default Re: My Integra GSR Transmission Build/Assembly
This is gonna be good. Your turbo thread was very detailed and interesting.
Old 04-01-2012, 06:59 AM
No-Traction = Fun
Thanks, man much appreciated!!
Old 04-01-2012, 08:21 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Can't wait for this. I might be comfortable enough to crack my tranny and install a ls 5th and a mFactory LSD after this right up. Trannys have always been something I have found intimidating(no homo)! Thanks Cali dad for your contributions. You are inadvertantly helping me save money.
Old 04-01-2012, 08:43 AM
hondad6's Avatar
Here for the tranny build.
Old 04-01-2012, 11:39 AM
No-Traction = Fun
Thanks guys! Well I pulled a few bolts and out she comes. My clutch and flywheel look pretty good for all the dyno tunes and abuse I have put her threw.
Old 04-01-2012, 11:43 AM
No-Traction = Fun
I scuffed up the flywheel and pressure plate a little. Since I have it apart I plan on installing a new 4 Puck Spring hub disc, pilot bearing and an ACT throw-out bearing. Call me crazy, **** or whatever... but since is will be sitting outside for a few days i wanted to cover things up. The desert winds are nasty right now and blows dirt & dust in places you don't want it!
Old 04-01-2012, 01:46 PM
No-Traction = Fun
Here is the LSD im using, i bought the upgraded bolt and washer kit for this LSD. Also picked up the carbon syncros 1-5. I pulled the LSD apart to reveal the inside. Looks like OBX cleaned up there more recent units. Non of the stock bolts were stripped and the washers were installed correctly. You probably don't need to go as extreme as I did and mark everything before you disassemble it. I also wanted to make sure the axles splines didn't bind up on the inner gear. would rather know now before its all installed. Now for a little bit of de-burring!!
Old 04-01-2012, 08:09 PM
No-Traction = Fun
And here are a few more pictures of the LSD re-assembly.
Old 04-01-2012, 08:17 PM
No-Traction = Fun
And now to crack open the transmission.
This is a picture of all 16pc case bolts removed.
Old 04-01-2012, 08:28 PM
No-Traction = Fun
You are going to want to buy a new set of ring gear bolts, They are reverse thread and are torqued to 80ft pounds and they normally strip slightly when they are being removed. (Note The Picture)
If you cant buy a new set of bearings you can use a bearing puller and re-use them.
Old 04-01-2012, 09:38 PM
No-Traction = Fun
And now on to changing out my 1st thru 5th syncro's
Old 04-01-2012, 09:47 PM
el crapitan's Avatar
right on. thanks for taking the time to keep it so detailed
Old 04-02-2012, 04:23 AM
No-Traction = Fun
Welcome. I was surprised on just how easy it was. Not scary at all!!
Old 04-02-2012, 04:25 AM
No-Traction = Fun
Before I go any furher I need to order a few things
1. New diff bearings (roller style)
2. Shim Kit
3. Trans Seal Kit
4. New Ring Gear Bolts
5. New Clutch Disc
Old 04-02-2012, 06:25 AM
yeah, it doesn't look all that complex. like anything, keep the area clean, keep your **** organized, and make sure it all goes back the way it came off.
auto tranny's though on the other hand...
Old 04-02-2012, 07:08 AM
No-Traction = Fun
Oh, Yeah I agree.
Old 04-02-2012, 09:40 AM
mouab18c1's Avatar
Good thread, digging the garage!
Old 04-02-2012, 12:45 PM
kbouchard1092's Avatar
Did you buy the newer style Bearing for the LSD? those types of bearing need to have a pre-load set....The newer style have a enclosed bearing, not a roller bearing with the outer race. Then you would need to buy the correct sized Shim as wel pending on the clearance from the transmission case and outer race of bearing once case is put back on...I had those style bearing on mine and switched to the enclosed bearing from the 99-00 SI for the LSD.
I ask cause you mention re-using them and you do show a bearing puller on them. I had a really tough time finding them, and ended up opting for the newer style bearings
Also off topic, is that a Cat or is it gutted out?
Old 04-02-2012, 01:30 PM
No-Traction = Fun
Yes I ordered the new style bearings with the shim kit for the new LSD, As far as my CAT its a 3" super duper mega high flow.....hint hint...if you know what I mean.
Old 04-02-2012, 01:44 PM
haha yea i get you, i was going to say no wonder you came short of 500. Yea exactly what i did as well as far as bearings. So much easier to install too, no need to worry about pre-loading it
Old 04-02-2012, 06:43 PM
P.O.S P5's Avatar
What size are the transmission bolts that go from the engine to transmission?
H22a4
Old 04-02-2012, 06:58 PM
AssPenny's Avatar
Nice write up! Also, that has got to be one of the cleanest tranny cases I have ever seen.
How do you like the carbon syncros? Notice a difference?
Craig - Who's split way to many dirty *** tranny cases.
Old 04-02-2012, 09:28 PM
No-Traction = Fun
H22a4
Well most of them are 17mm head.
Old 04-02-2012, 09:31 PM
No-Traction = Fun
Thanks I do like to keep my engine and trans clean! As far as the syncros go I have not installed the trans yet. I'm waiting on parts.
Quick Reply: My Integra GSR Transmission Build/Assembly
