My car beeps when I hit my brake!
Old 07-17-2016, 09:47 AM
stringseagle's Avatar
Default My car beeps when I hit my brake!
I have a 92 integra b18a
Initially I had a problem with starting my car.. it could push start no problem. got a new starter, alternator is good.. battery replaced changed some ground wires and voila it starts.. For a day or so, turning on the headlights would nearly shut the car down, that stopped happening, but NOW... anytime I hit my brake pedal weird things happen.
1. With no key: press brake at any pressure, makes THIS SOUND
When I let go of the brake the sound stops and my radiator fan turns on and the only way to turn it off is to put the key in the ignition, turn accessories on and then it turns off and I can take the key out and everything is off as it should be. Every time.
2. When the car is on and parked: pressing the brake pedal dims all dashboard lights including radio LED for as long as pressed, releasing brings all lighting back to normal. Every time.
3. When driving the car: pressing brake pedal dims ALL vehicle lights. Headlights and interior lights. Turns off radio momentarily. Every time.
Prior to fixing the ignition issue, this new issue did not exist. Ran smooth as butter other than the push start. Also I hear clicking behind/near my glove box which I believe might be a battery relay? Not sure.. So it feels like I am chasing a gremlin here. Any Ideas?
Old 07-17-2016, 10:30 AM
On vacation
testify's Avatar
Default Re: My car beeps when I hit my brake!
I'd focus on the ground wires, or whatever else you messed with.
Old 07-17-2016, 01:57 PM
fcm
Old Fart
fcm's Avatar
Ditto the above^^^ when any unrelated circuit has an effect on another circuit, [pressing brakes, dims lights] it is almost always a grounding problem. 94
Old 07-17-2016, 05:41 PM
The grounds that I worked with are brand new and very straightforward, tran to battery, block to frame. What other grounds should I be looking for?
Old 07-17-2016, 05:46 PM
On vacation
testify's Avatar
Any old ground that you removed, any new ground that you installed is what you should look at.
Old 07-18-2016, 06:53 AM
Yea the grounds are brand new, the only 2 I messed with battery ground to transmission and engine block to frame.. I have checked and rechecked them.. there is no corrosion, they aren't crossing over onto anything, nothing electrical is even remotely near them... So what other grounds should I be looking at?
Old 07-18-2016, 11:13 AM
GreatWave's Avatar
Check the ground on the thermostat housing as well.
Old 07-18-2016, 04:08 PM
fcm
Old Fart
fcm's Avatar
There are all sorts of grounds in both the engine bay and inside the car, mainly under the dash, your just checking the main grounds, [first thing you should have done] now start checking the rest, you will need a ground location schematic.
Just for ***** and giggles and it can't hurt, check your main power connections, batt. to engine bay fuse box and main fuse connections. 94
Old 07-30-2016, 11:09 AM
I have checked all the grounds that I can find, cleaned out the contacts for the thermostat ground as well. There is a chip in the main power fuse under the hood so I am going to replace that and see what, if any, effect it has. Anyone have a good site that has such a ground location schematic, that a layperson can read
Old 07-30-2016, 03:49 PM
tamboo's Avatar
get one at h*ndaho*kup (reg required).
z3pp3h
16
02-17-2014 04:31 PM
tsdenny
04-24-2009 10:47 AM
crazihobo
02-25-2009 06:00 AM
foxfai
12-17-2007 10:18 AM
Quick Reply: My car beeps when I hit my brake!
