Misfire when headlights come on?
Okay, so I have noticed that if I switch my headlights on and off, the car will misfire, throw a code and act fine. If I do it quite a few times it'll shut off and start back up like nothing.
Codes thrown are the following.
Code 4 - crankshaft position, distributor
Code 15 - ignition output signal, distributor?
Code 43 - fuel supply, apparently O2?
I get code 43 after driving a bit. Doesn't concern me much.
However what concerns is I only get the other two codes when I switch the headlights on and off and on, like literally back a forth.
Re: Misfire when headlights come on?
info about the car needed...a jdm front would play a huge roll if you have that...stock headlights or hids obd1 or 2 with step down.
post the specs
post the specs
