Metric Left Hand Thread Nuts (reverse thread) - Honda-Tech
Old 05-19-2004, 07:34 PM   #1
oMek's Avatar
Default Metric Left Hand Thread Nuts (reverse thread)
i just got some aftermarket heim endlinks in today. they are missing the nut between the joints that will allow you to lock it down so they dont swivel
they are m10 X 1.50, one side is reverse threaded and i cant find a bolt to fit it anywhere.
anyone know where i can get 1?
oMek is offline   Reply With Quote
Old 05-19-2004, 08:17 PM   #2
oMek's Avatar
Default Re: Metric Left Hand Thread Nuts (oMekoneDC2)
anyone?
Old 05-19-2004, 08:23 PM   #3
Will you make something up for me please?
shamoo's Avatar
Do you have a Lowes home improvement store where you are? It's similar to a Home Depot, but a little newer.
The Lowes near me have a very large selection of metric bolts/nuts. Much more than Home Depot which has like 10 total. I remember going to Lowes for many replacement Honda bolts that I lost during my work.
shamoo is offline   Reply With Quote
Old 05-19-2004, 08:23 PM   #4
mrxracing's Avatar
if not a hardware store, find a metal shop to make one or rethread the one you have
i know might not be much help but machine shops are the **** the do all kinds of miracle work
good luck bothah!!
mrxracing is offline   Reply With Quote
Old 05-19-2004, 09:07 PM   #5
Dan GSR's Avatar
Default Re: Metric Left Hand Thread Nuts (mrxracing)
if its for a swaybar endlink
don't even bother
cuz the endlinks won't spin anyway
Dan GSR is offline   Reply With Quote
Old 05-19-2004, 10:39 PM   #6
oMek's Avatar
Default Re: Metric Left Hand Thread Nuts (Dan GSR)
ya i tryed lowes, they had lefthand standard size but no metric
and yes its for a swaybar endlink
look at the pics notice the 1 bolt diffrence. do i really need 1? if i cant find it i was gona have a shop weld it in place
Old 05-19-2004, 10:44 PM   #7
esponet's Avatar
i don't see a reason why it would back out without the lock nut. the onlything i could think off is that it would be a stiffer conection with the lock nut. why don't you replace the whole thing. you could buy those at any hardware store. or if not try contacting a machine shop,hot rod shop, or a hardware store they might be able to help you locate the nut
esponet is offline   Reply With Quote
Old 05-19-2004, 11:07 PM   #8
oMek's Avatar
Default Re: (esponet)
i just figured that with out the lock nuts the 2 peices would turn with the swaybar and it moved and that cant be good at keeping in stiff
Old 05-20-2004, 02:05 AM   #9
oMek's Avatar
Default Re: (oMekoneDC2)
ok well i just found 1 on some site for 1.10$ i hope its the right 1
Old 05-20-2004, 02:37 AM   #10
oMek's Avatar
Old 05-20-2004, 04:08 AM   #11
tegmech's Avatar
Quote:
Originally Posted by oMekoneDC2
im looking through our book right now and i can't find any left hand threaded metrics. Can you even find it on our website? I hate these new catalogs they just gave us. Can't find a darn thing.
tegmech is offline   Reply With Quote
Old 05-20-2004, 12:43 PM   #12
oMek's Avatar
Default Re: (tegmech)
Quote:
ya on your site i searched for "m10 left" and it came up. i wint to 1 of your local stores and they said they gota order it form texas and it wont be here till wensday or friday of next week
Old 05-20-2004, 01:11 PM   #13
Function7's Avatar
Jam nuts are not required for our endlinks. They are intended to be a little loose (just a hair) and they do not rotate since the linkage bolts hold them in place.
Please ensure that both sides are set "neutral" and that you have at least 5-7mm of thread threaded into the linkages.
Thanks
Function7 is offline   Reply With Quote
Old 05-20-2004, 01:24 PM   #14
oMek's Avatar
Default Re: (Function7)
Thanks
you sure? i mean your endlinks looks almost exactly like comptech's and they use jam nuts.
i guess ill put them on without and see how i like it
Old 05-20-2004, 03:21 PM   #15
Function7's Avatar
That's right. As long as you have them set correctly and ensure that the ends apply no preload on the swaybar when the car is on a flat surface the setup will be good.
Once you have them installed, you'll notice that the top half and the bottom half will be "loose" but they will not unscrew more than 1/4 turn from each other and the two halves will never disconnect because the two mounting bolts hold them in place.
Thanks
is the crankshaft nut reverse thread 250r king Honda Civic / Del Sol (1992 - 2000) 9 06-23-2008 04:01 PM
Are either of the front axle nuts reverse threaded? professor poon Honda Civic / Del Sol (1992 - 2000) 12 04-11-2006 08:05 PM
axle-hub nut need help acc0rdp0wer Honda Accord (1990 - 2002) 7 02-15-2006 08:45 AM
2001 v6 axle nut removal? -RedneckDave- Honda Accord (1990 - 2002) 3 02-27-2005 01:20 AM
axle nut threading? deviant1 Honda Civic / Del Sol (1992 - 2000) 13 10-23-2003 08:29 AM
Tags
atv, bolt, carry, europe, hand, hex, honda, left, lowes, metric, nut, nuts, reverse, thread, threaded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
