maint req
Old 11-18-2004, 05:42 PM
andrew-0's Avatar
Default maint req
I got a 99 ls, the light goes on when the ignition is on, flashes 10 short times. Its kinda time for me to change oil, since the last time I did it was 3 months ago, and about 3000 kms, so is it because of my oil?
Also the oil level was in the middle level dot, so I added some more since it was a little bit low.
Anyone knows what the problem here is?
Old 11-18-2004, 05:45 PM
sabotage7's Avatar
Default Re: maint req (andrew-0)
read this!---> http://www.team-integra.net/se...D=483....no problem, just a reminder!
Old 11-18-2004, 05:51 PM
BlueIntegraBoy's Avatar
It goes on when the odometer hits a certain amount of miles. I believe every 20,000 miles.
Old 11-18-2004, 05:58 PM
andrew-0's Avatar
Ok, so what includes a regular maintanance? Things like oil level/change, coolant liquid, stearing/breaks fluid, spark plugs?
I mean what things should I check before winter, because I am not going to take it in for maintanance. Yep, Im cheap.
It hit 65 000 kms. Thanks.
Old 11-18-2004, 07:38 PM
Default Re: (andrew-0)
Oil change, that's pretty much it. Maybe spark plugs for a tune up. I thought Canadian cars didn't have a maintenance light, at least the SiR and ELs didn't.
Old 11-18-2004, 07:43 PM
sabotage7's Avatar
Default Re:
Maintenance schedule:
Every 250 miles or weekly-
check oil level
check coolant level
check washer fluid level
check brake fluid level
check tires and tire pressure
Every 3000 miles or 3 months-
all items listed above plus:
check power steering fluid level
check auto tranny fluid
change oil and oil filter
Every 7500 miles or 6 months-
inspect and replace, if needed, the windshield wiper blades
check and service the battery (i clean the terminals and relube w/dielectric grease)
check and adjust, if needed, engine drivebelts
inspect and replace, if needed, all underhood hoses
check the cooling system
rotate tires
check front brake pads
Every 15000 miles or 12 months-
inspect the brake system
inspect seatbelts
adjust the valve clearances
replace the air filter (may need earlier depending on driving conditions)
inspect the fuel system
check manual tranny lubricant level
inspect the suspension and steering components and cv boots
inspect the exhaust system
Every 30000 miles or 24 months-
replace the spark plugs (if you have non-platinums)
inspect and replace, if needed, spark plug wires, distributor cap and rotor
check and replace, if needed, pcv valve
replace the fuel filter
check and adjust, if needed, the engine idle speed
service the cooling system (drain, flush and refill)
change the brake fluid
change the auto tranny fluid
change the manual tansaxle lubricant
Every 60000 miles or 48 months-
replace the spark plugs (if you're using platinum plugs)
Every 90000 miles or 72 monts-
replace the timing belt (water pump replacement is recommended at this time)
this was taken from my haynes manual, i edited and added some things too!
Old 11-18-2004, 08:41 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew-0 &raquo;</TD></TR><TR><TD CLASS="quote"> I got a 99 ls, the light goes on when the ignition is on, flashes 10 short times. Its kinda time for me to change oil, since the last time I did it was 3 months ago, and about 3000 kms, so is it because of my oil?
Anyone knows what the problem here is?</TD></TR></TABLE>
Don't listen to anyone but me, next time it comes on, you better run, your car is going to explode@!
Old 11-18-2004, 08:42 PM
sabotage7's Avatar
Default Re: maint req (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Don't listen to anyone but me, next time it comes on, you better run, your car is going to explode@!</TD></TR></TABLE>
oh crap! did i forget to tell him about the explosion!?.....i hope he's okay!
fafsa
01-24-2005 04:10 PM
brownman72000
10-07-2002 08:52 PM
redteg1
08-27-2002 10:39 AM
Digital-R
08-02-2001 12:59 PM
Quick Reply: maint req
