Ls vtec tensioner pulley
Its me again... haha... here's where I'm at... finally got the crankshaft pulley off, and the lower timing cover... went to loosen the tensioner pulley and loosened it pretty far out where the washer could slide back and forth and noticed that the belt was not loosened... being my fist time doing this loosened it more... nothing... asked a buddy and he asked if the spring was missing... of course it was... but that doesn't help my problem... soooooo here's the problem tensioner pulley spring is missing, but the belt was still tight and ran fine (until my oil light started flashing, but still ran normal), I traced the number on the gates timing belt and it turned out to be a non vtec timing belt, I looked at the water pump today thinking they were mix matched but it says 22t as in im assuming 22 teeth... I ended up taking the bolt all the way off the tensioner pulley so I could remove the belt... why was it so tight on there without the spring? anyone else ever see this? And the slit in the pulley where it slides to tighten and loosen was all the way at the tightened position, even with the bolt loosened
Re: Ls vtec tensioner pulley
scratch that... I had it mix matched... figured out my own problem... timing belt is non vtec, and water pump is 22 teeth vtec... So heres my question... can I use a non vtec water pump and fix it (I already have a non vtec water pump at my house that came with the car). Or should I spend the money and get both a new vtec timing belt and water pump... The non vtec timing belt is also new... maybe 500 miles on it so I really didn't want to replace it. Thanks
Nah... idk how much you know about ls vtec but ls timing belt = ls water pump and vtec timing belt = vtec water pump... you cant switch them... that's what someone did with mine
Yep got it back up and running... my friend that did the timing belt stretched the non vtec belt to make it work with the vtec water pump... not the first time I heard of him rigging stuff together... its done right now... went and got a new non vtec waterpump and she's up and running again
89sparks
08-31-2007 06:27 PM
DocSean
01-16-2006 09:20 PM
