ls/vtec question ??head gasket
Old 06-19-2011, 08:19 AM
97 civic lsvtec's Avatar
Default ls/vtec question ??head gasket
on an b18b1 what head gasket do i use for a b16 head
the ls head gasket or
the b16 head gasket ?
Old 06-19-2011, 03:08 PM
integratyper1990's Avatar
Default Re: ls/vtec question ??head gasket
ive been out the game for a while. I used to have a Lsv setup im pretty sure u need a hybrid LSvtec head gasket. i think golden eagle sells a lsvtec kit.
http://www.lightningmotorsports.com/...m/g-54400.aspx
Old 06-19-2011, 03:09 PM
also gunna let you know that it is one of the most unreliable motors
Old 06-19-2011, 04:46 PM
1998GsRIntegra's Avatar
As far as gasket goes you can use either. Some people say the non-vtec gaskets sit better than the vtec gaskets, but its really a matter of opinion. Personally I would go with a golden eagle.
Check this thread out if you haven't already. Lots of good info. --> https://honda-tech.com/forums/showth...ghlight=bambam
Old 06-21-2011, 12:10 PM
1ls/vtec's Avatar
Get the GE ls/vtec conversion kit. I have it on my LSV swap. It has 50-60k miles on it and still runs like it did when it was first built. Had a guy build it for me, since I had no clue on how to do it. Fun swap though if u have some ITR pistons in it. Good Luck man
Old 06-21-2011, 03:16 PM
phaphon's Avatar
i always used the ls head gasket works good for me so far
Old 06-21-2011, 03:42 PM
Shade460's Avatar
dont mean to thread jack but what makes them so unreliable ?
Old 06-21-2011, 04:42 PM
phaphon's Avatar
people not building them right
Old 06-21-2011, 04:52 PM
Shade460's Avatar
i have a B18 and i feel confident its right, u can check it if u think im wrong,
Old 06-21-2011, 07:37 PM
I requested a short story for a title.
stocker2shocker91's Avatar
people that dont build them right, people that think that because they now have a head that can rev to 9 grand the whole motor now magically can, people that run hack job half *** cheap oil lines and kits.
see sig, im running and ls/v turbo and i LOVE IT!!
but for the head gasket, i have the cometic ls vtec specific headgasket
Old 06-22-2011, 12:52 AM
HT Black OPs
00IntegrAllmotoR's Avatar
Use a vtec gasket or Golden Eagle ect....
http://www.goldeneaglemfg.com/includ...yGEMgasket.jpg
Old 06-22-2011, 07:12 PM
phaphon's Avatar
i loved my lsv turbo but too bad i couldnt ref my motor and came across a good deal on a 2000 gsr
Old 07-31-2011, 03:50 PM
siregcivic's Avatar
im doing an lsvtec today... i have golden eagle dowel pins and im going to use a 2layer gsr headgasket why do u ask i use a gsr headgasket, well because instead of tapping the hole in the bottom of the head, i had mine tig welded and machined, and i would rather my coolant ports line up and my oil drain ports be off by a little then the other...
maddcrx
07-22-2008 03:55 PM
vtec4max
06-19-2007 02:11 PM
tunedek
02-26-2005 12:01 PM
wade
07-01-2004 04:55 PM
zCivic
01-09-2003 09:56 AM
Quick Reply: ls/vtec question ??head gasket
