LS/Vtec or not
LS/Vtec or not
I have a 90 teg. with 170,000 on the motor and body. Would it be in my best interest to do a LS/Vtec swap or to dump a nasty set of cams in it.
Re: LS/Vtec or not (wernhersey)
depends on your goals. The real way to take advantage of any ls engine is the pistons. Whether your going ls/v or N/A with the ls, pistons will help out alot.
I hate everything
Re: LS/Vtec or not (bluemax189)
I'm pretty much in the same situation. 91 integra, 208 on the block, just getting another b18b bottom end w/ a gsr head, and then build. I will probably go boost too.
Re: LS/Vtec or not (Backk InTheDA)
Save what ya got, do what i did..
Pull your B18, get a rebuild with some high compression/low compression if you want turbo later forged pistons, rods and new bearings then go LS/V
TougeCoupe
05-29-2005 05:58 PM
