LS Sunroof question....
Hey guys, I recently got my first 97 ls, and the only damn problem with this car is for some reason the sunroof does not sit flush on one side? Everything fine though, it rolls back fine, closes good, does not leak at all, but it just wont sit flush on the one side.
Anyone have any similar problems with this? or anyone know the soulution to my problem? any help if appriciated!! thanks alot guys.
Re: LS Sunroof question....
Hi dude!!! Once I fixed my sunroof on a Civic EX, but all sunroofs technology are kind of the same, let me try to explain that, I dont speak technical english :S
You are going to need to open or take out the roof panel, then first of all check that all the screws are properly adjusted.
Then try to take the sunroof glass out, you are going to need to remove the side panels on the glass, check this pic
This is the part I don't know how to explain jajaja... if you take the glass out on each side you are going to see some packing rings (nice google search) you can remove some packing rings from the side to adjust the glass height, hope is the same thing as the civic... give it a try... better is nothing jeje
Cheers
Cheers
Might just be an acorn or something jamming up the works in there. Unscrewing the sunroof glass bracket from the rails (takes a hex key) will let you clean out anything that might be in the way of those. It's really not hard to take off. Pop the sunroof a little bit and look from the inside of the cab. IIRC there are 6 bolts.
