LS knocking at startup
Old 10-06-2013, 01:16 PM
LS-Turbo!!'s Avatar
Icon6 LS knocking at startup
I have an 95 integra timing belt snapped on 1st owner. I got the car and replaced the whole head (b20) car was driving fine for a week when I was on the freeway I felt loss in power and started slowing down and died before I could get to the side it started back up now my oil light was flashing. My first thought F***!
So I pulled over ASAP checked the oil was a little low not too bad went to go start it up and there was a knock but then went away first thought oil pump! So I kept the rpms low just to get down the street and noticed a knock at about 23k rpm replaced the oil pump started the car and let it warm up light started flashing killed it now i am here looking for any help I do have vids and will post to YouTube ASAP I know I could if bent a rod or spun a bearing but want to get all of the little stuff it could be out of the way first
Old 10-06-2013, 01:17 PM
LS-Turbo!!'s Avatar
Default Re: LS knocking at startup
The knock is still there as well
Old 10-06-2013, 07:11 PM
m4xwellmurd3r's Avatar
You ran it low on oil and spun a bearing. Now you have rod knock
Btw this isnt a little problem, and requires a full engine rebuild. And possibly a new crankshaft (99% of spun bearings trash honda cranks as the nitride layer is too thin to be turned down)
Old 10-06-2013, 07:49 PM
LS-Turbo!!'s Avatar
Thank you. That was my suspicion. Im just swapping it out with an a1 block and building this one. Just picked up some eagle rods too
ramboPandA
09-17-2018 02:25 PM
spoolin08
06-02-2011 04:40 AM
Skitso's CB7
05-03-2011 03:50 PM
StockDC2
09-01-2009 08:59 PM
keepinitsimple
14
11-07-2004 10:28 PM
Quick Reply: LS knocking at startup
