ls crankshaft vs GSR crankshaft - Honda-Tech
Old 09-13-2008, 11:27 PM   #1
Ricextacy's Avatar
Default ls crankshaft vs GSR crankshaft
as u all know i fuked up my GSR crank shaft..
im getting a 95 ls crankshaft for free from a friend.
do you think ill be losing power if i use that?
and
is the gsr flywheel still gonna bolt on to the ls crank.
Ricextacy is offline   Reply With Quote
Old 09-13-2008, 11:31 PM   #2
Ricextacy's Avatar
Default Re: ls crankshaft vs GSR crankshaft (Ricextacy)
it does feel like a dumb question, i would want to say "yes, i will lose power" but on the other hand its still B series...ive seen it handle vtec all the time.
i looked up the parts and they both have different part numbers..
i would buy a gsr crank, but its hard to find any for sale.
Old 09-14-2008, 12:06 AM   #3
Ls_Turboteg's Avatar
from what i have been told the ls crank is actually a really good crank i think it would be good but thats just from what i have heard...
Ls_Turboteg is offline   Reply With Quote
Old 09-14-2008, 12:22 AM   #4
if you picked up some ls rods with that crank you could see some power gains in your gsr make sure you use GSR or higher compression ratio'ed pistons. you would prolly need a tune after that though. Its like having A poor-mans Ls-Vtec lol. Youll get a little more torque. Just make sure you upgrade the Ls rod bolts to some arp's and get all Ls bearings. Maybe even cams and an intake mainfold
Horseofcourse is offline   Reply With Quote
Old 09-14-2008, 12:46 AM   #5
Ricextacy's Avatar
Default Re: (Horseofcourse)
Quote:
fo sho man! i am now looking forward to installing it now.
Now how about the flywheel? will the gsr flywheel bolt on to the ls crank??
Old 09-14-2008, 01:20 AM   #6
racebum's Avatar
Default Re: (Ricextacy)
what did you do to your GSR crank? if you just scared it from fried bearings it can probably be cut under.
racebum is offline   Reply With Quote
Old 09-14-2008, 02:14 AM   #7
IntegraMark's Avatar
IIRC, all the threads that hold the flywheel are stripped.
OP - it's too bad you don't live around me. there's a wreckers about 20 min from my place that has a complete B17 bottom end just laying on the ground in front of strpped DB2.
IntegraMark is offline   Reply With Quote
Old 09-14-2008, 07:37 AM   #8
Default Re: (IntegraMark)
Gsr Crank 87mm
Ls crank 89mm
You'll gain a good amount of torque/power.. You'll have to use ls rods tho, so i suggest using upgraded Rod bolts, which is the only weak link in the ls block. That crank is good and strong.
IntegraType-R is offline   Reply With Quote
Old 09-14-2008, 09:51 AM   #9
And to answer your question yes the Gsr flywheel will bolt up. But i suggest a lighter one. It will spin your motor up faster.
Old 01-21-2009, 07:03 PM   #10
loosh's Avatar
late as **** but the ls crank is the only actual 1.8 crank. gsr/type'r are like a 1.75/76. Honda rounds up.
loosh is offline   Reply With Quote
Old 01-21-2009, 08:12 PM   #11
Man U FTW
Schister66's Avatar
If you use the LS crank, you'll obviously have to use the LS rods. The GSR crank is an 85.4mm stroke; whereas, the LS is an 89mm stroke. There is a bit of displacement to gain which in turn means a bit of torque. The choice is yours...
Schister66 is offline   Reply With Quote
Old 02-20-2009, 08:29 PM   #12
New User
Hey, im re-building my gsr for turbo, and i was putting the crank on the shelf, and it fell out of my hands and took a 2-3 ft drop to the concrete floor. it hit on the very corner where six bolt main is, but didnt mess up the bearing surface. Should i do any thing else other then balance?
xabsolutx is offline   Reply With Quote
WTB : GSR/B16 CAM CAPS, LS CRANKSHAFT, GSR CRANKSHAFT TravisBiggie Want to Buy 8 02-28-2015 10:25 PM
Wtb: gsr or ls crankshaft racereaper7 Want to Buy 6 06-20-2014 10:27 AM
WTB: GSr or Type r crankshaft 1999siguy Want to Buy 4 01-30-2009 11:45 PM
FS: ls crankshaft for sale electric_rex For Sale 1 11-14-2005 10:55 AM
Identify LS crank PTR1 Tech / Misc 2 05-04-2004 03:27 PM
Tags
acura, bearing, crank, crankshaft, differences, gsr, honda, identify, integra, ls, sale, shaft, stroke, type, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
