Low Beams Not Working - Honda-Tech
Old 10-22-2009, 04:29 PM   #1
sengalang's Avatar
Default Low Beams Not Working
Alrighty guys, im pretty stumped on this one.. woke up this morning to find that my low beams arent working.. i checked both left and right lowbeam fuses and the are just fine checked the one in the Engine bay as well.. everything else light wise works ranging from high beams to tail lights.
I dont believe its wiring issues although i cant be certain since i dont have a voltmeter to check the wires..
i tried searching to see if anyone has had the same problems there was a few but their problems werent solved i guess..
Aftermarket Angel eye halo ( if that helps in anyway )
oh and its not the bulbs, they are fine as well
you guys think that the relay might have fried?
im actually not sure where exactly the relay is. Can someone point me out where it is so i can check?
2000 Integra GS-R
Thanks..
sengalang is offline   Reply With Quote
Old 12-09-2009, 09:28 AM   #2
New User
Default Re: Low Beams Not Working
I have the same problem did you find a fix?
KATKINSON is offline   Reply With Quote
Old 01-15-2010, 03:13 PM   #3
New User
2000 Integra GS-R
Thanks..
Same problem with Honda Civic 2006 (Regular Bulbs) any fixes?
massicg is offline   Reply With Quote
Old 01-16-2010, 04:35 PM   #4
Check your relay it might be stuck on high beams. That's what happened to a car a while ago on me it was just the relay. If you have a spare relay or even one from the engine compartment that will fit swap it out with the headlight relay and see what happens.
rxbahamut is offline   Reply With Quote
Old 01-16-2010, 05:29 PM   #5
Go get a chepo radio shack Volt Ohmm meter, check and see if your getting power to your bulbs. If you are getting power to the bulbs you need to start checking for grounding issues.
No power to bulbs start checking relays replace fuses even if they look good and headlight switch
TheAsian is offline   Reply With Quote
1998 CR-V low beam headlight issue pr1madona Honda Element & CR-V 1 10-01-2016 12:52 PM
headlight/ high beam problem Evan125 Honda Civic / Del Sol (1992 - 2000) 5 12-07-2009 09:00 PM
driver side headlight has no power mrbleegs Honda Prelude 1 08-09-2009 09:02 AM
high beams not working. powerwagon340 Honda Civic (2001 - 2005) 9 12-24-2008 02:07 PM
Tags
1988, 92, accord, acura, beam, beams, crx, ep3, high, honda, low, lowbeams, prelude, problem, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
