This Just started happening!
Old 04-14-2007, 09:42 AM
Babakarab's Avatar
Default This Just started happening!
Just recently only when i start my car cold and when im starting in first gear. I hear this like rattling almost, i cant exactly explain the sound its like metal bouncing around. Its not very loud but i can hear it every time. its coming from my engine. What coudl this sound be? anyone else experience it. 95k miles btw. 98 GSR
Please help I want to make sure it is not major.
Old 04-14-2007, 10:11 AM
Ldc4S's Avatar
Default Re: This Just started happening! (Babakarab)
I had something like this before, turned out to be my heatshield with loose bolts. Have you checked?
Old 04-14-2007, 10:24 AM
Babakarab's Avatar
Default Re: This Just started happening! (Ldc4S)
hey that sounds like it could be it. I will definetely check that out. did your noise only come when you first drove the car.
Old 04-14-2007, 11:45 AM
TSX TEX's Avatar
does it sounds something like a metal chain dragging across metal
Old 04-15-2007, 12:15 PM
Babakarab's Avatar
Default Re: This Just started happening! (iPnTegRa)
If you are talking about the timing belt than......
no i checked the timing belt like 3 months ago and all the grooves in it were still rigid. previous owner stated he changed timing belt at 65k miles. it looks like it has been changed, and a mechanic says it looked OK. I think it might be the heat shield, but it only does it really when you first start driving it like first few feet.
Old 04-15-2007, 10:28 PM
Babakarab's Avatar
any more ideas??
Old 04-16-2007, 12:29 AM
91DBSexyTime's Avatar
go over your whole exhaust system front to back, something is loose, maybe your pipe came off a hanger, mine does that, and thats the issues with custom pipes and bad weld spots.
CivicSos
20
04-21-2014 06:00 AM
Psycho719
09-14-2011 04:28 AM
Blacktt7
11-28-2007 05:12 PM
CRzex
02-24-2002 07:17 PM
98TypeR
08-01-2001 08:30 AM
Quick Reply: This Just started happening!
