Integra won't move in gear
My integra wont go when I am in any gear, I was driving in first gear and my car just started reving. I just replaced the left axle But when I step on the gas in first gear the speedometer still says zero and wont move. Before it happened my wheels felt like they were wobbling on the passanger side. Car will still go in to every gear. Could this be the transmission? clutch or axles? The clutch showed no signs of slipping or anything. Please help thanks.
Old Fart
Re: Integra won't move in gear
Check the axle you installed, is it properly "inserted" into the transmission?
Is it the correct axle?
Are you sure you are in gear?
Have you tried another gear/reverse? 94
check ur right axle ( pax side )...thats were the wheel spins...jack ur car up, put it on a stand...then spin the pax side axle while u have it in gear. it should not spins, if it spins check ur axle and underneath around that area...you can also start the car and put it first gear.
