integra pulls right, why?
I recently raised up my integra for the winter in PA (stock shocks are on) , put my one season old winter tires on, and had the car aligned to spec. The car was pulling slightly left at first but i had the front two tires on backwards (blizzaks are directional tires who knew?) so i switched them and then the car was pulling slightly right. This is all after the car was aligned. Now, about two weeks or so later, the car is obviously pulling right even though the tire pressures are within the normal range. The car has no major accidents on record and has tracked straight in the past. What should i go about checking because this is pretty annoying.
Re: integra pulls right, why?
It has to do with that tire/wheel, since whatever side you put it on, it pulls that way. Could be out of round, or warped, or the thread is feathered really bad.
i'll have the wheels balanced, the car was pulling hard left when i had my coilovers on but i think that was just due to my beat *** neo gens. thanks for the input, i had few ideas to help out the situation
