Integra gsr no power
Recently my integra has not been getting power in first or second gear. The problem seems to happen after driving for a little bit and only if I come to a stop. If I come to a stop after the car warms up when I accelerate the car bogs really bad and hesitates like something is holding it back I can push the throttle all the way and the car will only go 5mph and this only happens it 1st and 2nd then the car just gets a surge of power and drives normal. I am throwing codes P0135 p0301 p0302 p1300 p1399. I changed my spark plugs,wires and distributor and still does the same thing. I also cleaned the iacv
Old Fart
Re: Integra gsr no power
Ditto the above, check both the valve and ign. timing.
I would also check the ECT sensor, you may be running rich.
Random misfires are almost always due to a fuel issue, when was the last time you changed the fuel filter, have you checked to see what the fuel pressure is yet?
Check the PGM-FI Main Relay...
http://www.tegger.com/hondafaq/mainrelay.html
http://techauto.awardspace.com/mainrelay.html
Fairly common problem on older Honda/Acura.94
I will check the timing on Monday since I'm not driving the car and I have never changed the fuel filter so I will try that also thanks I will update on the progress
checked the timing and it was good I heard some noises coming from the distributor so I removed the cap and there was dust and oil in there. I had warranty so I got a new distributor and everything is ok for now
New dizzy is also making noises I haven't adjusted it with the timing light yet but I don't think that would cause the dizzy to make noises or would it
