Integra blowing out blue smoke
Old 02-23-2009, 10:38 AM
KevinSmith88's Avatar
Default Integra blowing out blue smoke
everytime I hit the vtech theres blue smoke coming out, what can be the problem?
Old 02-23-2009, 10:45 AM
sirmugenpower's Avatar
Default Re: Integra blowing out blue smoke
running really rich
They let me pick
mrdeadman's Avatar
You are burning oil.
Old 02-23-2009, 01:52 PM
shawndb1's Avatar
How you treating your teg?
Old 02-23-2009, 01:55 PM
Mickeeezy's Avatar
blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. i suggest you check your o-rings/piston rings or gaskets.
Old 02-23-2009, 02:39 PM
DC206R's Avatar
yeah i think that ur gaskets are blown.
Old 02-23-2009, 03:21 PM
TOO MUCH TORQUE's Avatar
dont post when it comes to giving advice
blue smoke almost always means piston rings/valve seals
Old 02-23-2009, 03:23 PM
92integraVTECgsr's Avatar
do a compression test. if it is good. then it is your valve stem seals.
Old 02-23-2009, 04:20 PM
ef_junky's Avatar
but why would it be valve seals when he's got the throttle plate open and its suckin air that way.... usually valve seals can be noticable after the car has sat for a while and then when starting it up it puffs out a little blue smoke from where it leaked into the cylinders or when your going down a big hill (like in 4th) and your cruising at higher rpms off the throttle there will be alot of vacuum from where the pistons are try to suck air into the cylinders and the plate is closed so its will slowly suck a little oil past the valve seals and when you get to the bottom of the hill and give it some gas it will puff out a little smoke again...... just my .02
sde780
23
02-19-2013 05:02 AM
LaOXXKIDD
08-15-2009 12:05 PM
jdmcivicb16a2sc61
10-05-2006 05:17 AM
X-cement-filled-EG-X
04-05-2004 04:01 PM
Civic4drR8cer
07-13-2003 11:17 AM
Quick Reply: Integra blowing out blue smoke
