Intake cam gear bolt broke
Old 03-09-2010, 01:43 PM
88aeFC3S's Avatar
Default Intake cam gear bolt broke
okay, long story short. i'm replacing my timing belt and accidentally over-torqued the intake cam gear bolt and the bolt broke off. now half of the bolt is inside the cam shaft.
- what do i need to do to be able to take out the bolt inside the cam shaft?
- how much does a replacement bolt usually cost?
Old 03-09-2010, 01:47 PM
GagnarTheUnruly's Avatar
Default Re: NEED HELP, INTAKE CAM GEAR BOLT BROKE
Replacement bolts are probably cheap -- not sure what you can do about that camshaft, though. IDK if it's a good idea to try to drill it out. Maybe PB and vice grips if there's some thread sticking out. You may also be able to weld a nut onto what's left of the bolt and grab it with a socket wrench. GL.
Old 03-09-2010, 01:55 PM
Hatorade's Avatar
What engine specs?
maybe its a good time for a camshaft upgrade?
Old 03-09-2010, 01:56 PM
88aeFC3S's Avatar
theres no thread sticking out, so no go on the PB and vice grip idea. and i'm also debating if i should try to drill it out or just try to find another used cam shaft or something.
Old 03-09-2010, 01:57 PM
88aeFC3S's Avatar
Originally Posted by Hatorade
What engine specs?
- 1999 B18B1
- all stock
- 165k miles
Old 03-09-2010, 01:59 PM
I'd just get new a new cam. I bet you could find used LS cams super cheap. Going aftermarket might not be worth it for you if you're keeping her stock.
Old 03-09-2010, 02:00 PM
Hatorade's Avatar
Originally Posted by 88aeFC3S
- 1999 B18B1
- all stock
- 165k miles
i'm sure it will be easier to just buy a used camshaft. stock ones are everywhere and in low demand.
alternatively, you could grab the Crower 62402 which will give about 10hp and stronger top end. they run around $300 i believe
Old 03-09-2010, 02:04 PM
dntnedvtec's Avatar
Check on craigslist for some stock cams. Most guys will eventually throw in the bolt for the camshaft. the replacement bolt should be under 10.00. I paid almost 9 bucks for a tensioner bolt from the dealer.
I could be wrong but I think the cam bolt is tq down to 45 ft lbs.
Old 03-09-2010, 02:16 PM
Jockone's Avatar
Remove cam and take it to a machine shop and have them remove whats left ot the bolt or get a used one which ever is most cost effective for you.
88aeFC3S's Avatar
yeah, im not planning to upgrade the head any time soon. i just need to get my car running...
Technical Hero
HondaPartsHero's Avatar
happened to me before, used this and it came right out
Old 03-09-2010, 02:18 PM
dntnedvtec's Avatar
^ doesn't he have to drill a hole into the busted bolt? Then hammer that in right?
Old 03-09-2010, 02:21 PM
88aeFC3S's Avatar
yeah, someone on another forum also suggested that idea too. where could i find one of those tho...maybe advance?
Old 03-09-2010, 02:43 PM
88aeFC3S's Avatar
i think you drill a hole in the middle of the broken bolt then run the extractor in the hole. since it reverve pitched, it grabs the bolt and spins it out.
i just dont wanna **** up the threads inside the cam...
Old 03-09-2010, 08:57 PM
dntnedvtec's Avatar
You should be okay, just dont drill the hole at an angle. Drill her straight. using the smallest drill to mate witht he extractor. Go from there.
Old 03-09-2010, 09:04 PM
88aeFC3S's Avatar
thanks man. if i dont trust myself doing it, then i think ima just take it to a local machine shop to drill it out...
Old 03-10-2010, 11:36 AM
88aeFC3S's Avatar
Default Re: Intake cam gear bolt broke
problem solved!!
carefully used EASY OUT and the bolt came out...
Old 03-10-2010, 12:07 PM
95 integra's Avatar
BTW, LS cam bolts are 12mm (Vtec - 14mm) so they have lower torque specs and the bolts break much much easier.
Joe...
05-07-2008 03:35 PM
Mugencrxsir1
02-21-2006 02:55 PM
dblkack
03-16-2005 05:24 PM
JDMlyfestyle
11-20-2004 12:29 PM
JCCOOL43
02-12-2004 11:56 PM
Quick Reply: Intake cam gear bolt broke
