Ignition problem
Ignition problem
Hey guys, I own a 95 Acura Integra LS. I recently had an ignition problem that I cannot figure out. One day I went to start my car, and I turned the ignition and it started and I let go of the key and it shut off. I came to realize my ignition "On" position is out of place. When I turn the key to where the on position should be I get no power, no lights turn on or anything. If i move the key towards me back from the on position a tiny bit (in between Acc/On position) I get the power. So now when I start my car I have to manually move the key past the on position where it has shifted, and if I accidently hit my key or hit a nasty pothole it will shut off because the key will then move. If anyone has had a problem like this where their on position on their ignition or give me advice on how to fix this without replacing the full ignition that'd be great.
Re: Ignition problem
Well I believe I've found the problem after researching a little bit, and from what people have said it is the ignition switch. So hoping that'll fix it for 50$ which isn't as bad as paying 250$ for a whole ignition.
I have a long-standing page on this problem and how to fix it. See here:
Starting Problems
Starting Problems
Starting Problems
Starting Problems
allsho
02-10-2007 05:05 PM
