If your battery is dead, will your alarm still work? - Honda-Tech
Old 04-28-2005, 02:12 PM   #1
yung98gsr's Avatar
Default If your battery is dead, will your alarm still work?
My car will not start. When I push the button for the alarm, it is very faint. Not as strong as before. My cd deck reset like it was disconnected for the battery altogether. My interior lights also are very dim. Can my alarm disable power in the cabin also? I am at work and have no way of checking the battery. I am in no position to bump start it either. What should I do? thanks.
yung98gsr is offline   Reply With Quote
Old 04-28-2005, 02:17 PM   #2
jdmintegls's Avatar
Default Re: If your battery is dead, will your alarm still work? (yung98gsr)
no its not gonna work...unless you have a backup battery to your alarm
jdmintegls is offline   Reply With Quote
Old 04-28-2005, 02:18 PM   #3
Monkey Z.'s Avatar
u'll probably have to jump start it .. sorry. and no an alarm won't work if your battery is dead (unless you have a small back up battery wired to it). Electrical things need an electric current to work.^dayum beat me to it
Monkey Z. is offline   Reply With Quote
Old 04-28-2005, 02:41 PM   #4
StolenTeg's Avatar
Default Re: (DarkblueInteg)
The battery probably still have some power left in it to trigger your alarm/ interior light but it not strong enough to start the car, take the batter to a part store and test see if it dead.
StolenTeg is offline   Reply With Quote
Old 04-28-2005, 02:49 PM   #5
milton's Avatar
Default Re: If your battery is dead, will your alarm still work? (jdmintegls)
Quote:
back up battery!
milton is offline   Reply With Quote
Old 04-28-2005, 02:50 PM   #6
sabotage7's Avatar
Default Re: (StolenTeg)
Quote:
alarms barely use any power, so it could still work even if your battery doesnt have enough power to start your car.
sabotage7 is offline   Reply With Quote
Old 04-28-2005, 04:24 PM   #7
yung98gsr's Avatar
Well, I just jumped my car. After I hooked up the car battery to another, the alarm finally got enough juice to disarm and then I could start it. I hope it is only my battery that is bad. Changing an alternator is a bitch. Has anybody else changed their alternator without removing the axles?
Old 04-28-2005, 04:34 PM   #8
MOVE OVER's Avatar
Default Re: (yung98gsr)
dont know if u can without takin out the axle, but it would deff be alot easier if it were taken out.
one thing about some alarms tho, when the battery gets disconnected, some tend to want to "Go Off" once the battery is back in. so, have the remote handy. some do this, others dont.
good luck, hope its just the battery
MOVE OVER is offline   Reply With Quote
annoying factory alarm on my Ody 2004! HELP PLS! s1mpl31k1d Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 4 12-16-2010 01:34 PM
99 CX AlphaStatus Audio / Security / Video 7 11-23-2010 07:46 PM
Attention Electricians! 1992 Integra GSR: Alarm/Battery problem - NEED HELP! 92_Integra_GSR Acura Integra 2 04-01-2009 09:29 AM
alarm doesnt work after battery swap. SiB16A Audio / Security / Video 12 12-24-2008 03:01 AM
HELP I can't Start my car ... CLIFFFORD alarm won't let it happen!!! Firestarter Audio / Security / Video 2 01-30-2006 12:14 PM
Tags
acura, alarm, alarms, battery, car, dead, died, disable, disconnected, honda, integra, key, off, remote, rsx, work, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
